about to refrub kitchen and have the following in situ
cooker supply with 32a mcb wired with 10mm to 45a switch cooker and socket then 10mm to the CCU
im looking to install seperate oven (now on other side of kitchen) and hob same side as current supply.
the oven is 5.5kw and the hob 7.2kw
can i take both off the existing supply (leaving the 45a dp in place), the cooker would require a run over 6-8 meters from ccu using 6mm - and if so where do i spur from - the ccu
thx
thx
