Sealed systems run at about 1.5 bar, not high pressure in real terms. Joints, pipes, fittings and rads (etc) which are not leaking now, will not leak under 1.5 bar pressure. Sealed systems 1) get hotter quicker, 2) do not draw in air (as per previous post), which reduces corrosion, 3) do not need a header tank, which saves you loft space. My opinion would be to go for it. I have a sealed system which is fantastic. Only drawback is a small cost element for filling loop components (non-return service valve plus pressure gauge) and the need to manually check / top-up the pressure every couple of months or whenever system has been bled / altered.
HTH - Kind Regards.
________
CJG, U.K
