| Author |
Message |
pmxcrw
Joined: 13 Sep 2007 Posts: 10 Location: London, United Kingdom
Posted: Sun Jan 13, 2008 3:02 pm |
I've had a kitchen designed by MFI and paid the deposit. When the kitchen fitter came around he said it was impossible to fit the dishwasher where it was in the plans since the gas pipe come up out of the floor about 10 cm away from the wall.
The only other way to fit everything in would be to put the dishwasher where the sink is currently fitted (with a plain cupboard fitted around the gas pipes).
The problem is that the cupboard under the sinks currently has the gas meter in it (with some flexible pipe connecting to the steel gas pipe coming up from the floor). The meter would need to be moved so that it was next to the gas pipe.
Also, the mains water comes up out of the floor directly under the sink. These pipes have a stop valves that stick too far into the room (so the dishwasher would fit). The fitter suggested that the valves could be turned into the wall, and new valves fitted in the cupboard where the gas meter would be moved to.
He suggested that a CORGI registered central heating engineer could do this work, including re-locating the gas meter. Is this correct, or would I need to pay lots of money to British Gas? Also, can the valves on the main water be turned into the wall (as he suggests) without first turning off the mains water (we live in a large block of flats, I have no idea how we would do this).
Thanks in advance for any help |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
giblets
Joined: 03 May 2007 Posts: 2720 Location: Surrey, United Kingdom Thanked: 234 times
Posted: Sun Jan 13, 2008 4:04 pm |
Another case of the salesman not knowing his job by the sounds of it.  Should this problem not have been noticed at survey time? Might be worth asking MFI to pay for the moving of the meter. Unless, of course, you did the survey yourself and just gave the plans to MFI to design.
As the gas meter, governor and associated pipework to the emergency control valve are owned by the transporter of the gas (not the people you buy it from) then they are the only people who can resite the meter. Any CORGI doing the work would be a very silly boy IMHO! Then there's the small matter of earth bonding!
You really ought to find out where your primary (external) stopcock is as you may need it in a hurry one day when the internal one won't turn off. |
| Back to top |
gas4you
Joined: 23 Feb 2007 Posts: 16908 Location: Norfolk, United Kingdom Thanked: 500 times
Posted: Sun Jan 13, 2008 4:31 pm |
If it's a simple case of moving the gas meter to the otherside of the incoming gas main (within reach of the existing anaconda) then a normal RGI could just swing it round and connect your copper back up again.
If it is a physical move further than this you will need NG in. Probably around £400-£500. |
| Back to top |
ChrisR
Joined: 24 Jul 2003 Posts: 23083 Location: London, United Kingdom Thanked: 936 times
Posted: Sun Jan 13, 2008 4:37 pm |
A Corgi man can move the meter but only within the constraints of the flexible pipe between the Emergency Control Valve (gas tap) and the meter governor, which is fixed to the meter.
You could get the incoming gas pipe moved, but it might be cheaper to move house! |
| Back to top |
pmxcrw
Posted: Sun Jan 13, 2008 4:46 pm |
Thanks for the help. I assume by anaconda you guys are referring to the flexible pipe between the (steel) gas pipe and the meter. In this case the meter would be moved closer to the pipe (not further away). The only solid pipe is the copper pipe coming out of the meter into the central heating. Again, moving the meter would make things simpler here, since the new location is directly underneath the combi-boiler.
In term's of the water pipes, how would I find out where the external stop-cock was? (sorry if this is a dumb question, this is the first property I've bought). The flat is a third floor flat in a six storey block. |
| Back to top |
spudkey
Joined: 27 Oct 2007 Posts: 503 Location: Essex, United Kingdom Thanked: 70 times
Posted: Sun Jan 13, 2008 5:23 pm |
also remember the main gas isolation valve must remain accessible |
| Back to top |
ChrisR
Yes the red hose is the Anaconda.
Look for vertical ducts with panels in them, for your services. They're usually near ground level or in the stairway at the flat level |
| Back to top |
Garfeild
Joined: 19 Jan 2007 Posts: 1012 Location: Kent, United Kingdom Thanked: 108 times
Posted: Sun Jan 13, 2008 5:27 pm |
Ring the local water company,the numbers on your water bill,and get them out to identify which stopcock is yours. |
| Back to top |
cowboyplumber
Joined: 07 Nov 2004 Posts: 516 Location: United Kingdom Thanked: 2 times
Posted: Sun Jan 13, 2008 5:29 pm |
Any corgi with met1 and their permit to work from BG can move the meter. |
| Back to top |
