DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Rules for Gas Pipe clips and spacing.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
InTheBeginning2007
from United Kingdom
PostPosted: Fri Feb 01, 2008 4:19 pm Reply with quote
I am installing a a new boiler and the CORGI guy who will comission it, wants me to run the gas pipe too. He will solder joints, but I have to do the rest of the pipe work.
Are there any rules about securing 22mm copper gas pipes.
i.e type of clips to use, spacing of clips etc.
Thanks.
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 234 times
PostPosted: Fri Feb 01, 2008 5:25 pm Reply with quote
If you ask your CORGI man he will be able to give you all the required details.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 494 times
PostPosted: Fri Feb 01, 2008 5:34 pm Reply with quote
Yes
Back to top
 Alert Moderators
Trundles Tricks
from United Kingdom
PostPosted: Fri Feb 01, 2008 6:43 pm Reply with quote
I've never really understood why people quote rules and regulations as regards distances between clipping pipe.
If you think a pipe needs a clip at a certain point in the run to make it secure clip it!!
If that means 4 clips inside a 1 metre run then so be it..if it needs less then also so be it, the point is...is it secure or not?
It really doesn't get any more complicated than that.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 936 times
PostPosted: Fri Feb 01, 2008 7:29 pm Reply with quote
But too many plumbers think you can support 6m of pipe on a couple of nails, so the minima are important!
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 136 times
PostPosted: Fri Feb 01, 2008 7:32 pm Reply with quote
Back to top
 Alert Moderators
Corgigrouch
from United Kingdom
Thanked: 172 times
PostPosted: Fri Feb 01, 2008 7:41 pm Reply with quote
Is this a trick question?
One each end of course.. Unless you are economising..
Back to top
 Alert Moderators
leakydave
from United Kingdom
Thanked: 33 times
PostPosted: Fri Feb 01, 2008 8:45 pm Reply with quote
surely 4" nails through the gas pipe would make it far more secure and unlikely to fall off nails when simply placed on them!!!
Back to top
 Alert Moderators
kev_1911
from United Kingdom
PostPosted: Fri Feb 01, 2008 8:51 pm Reply with quote
i've switched to self tappers now as i am sick of bashing mi thumbs ! icon_lol.gif
and be sure to leave the head proud so you have somwhere to hang your manometer.............
Back to top
 Alert Moderators
InTheBeginning2007
from United Kingdom
PostPosted: Fri Feb 01, 2008 9:03 pm Reply with quote
Giblets and gas4you - why do you bother posting an answer like that.
Of course I would ask him - if I could. However he is on holiday at the moment and is intending to do my job as soon as he gets back, hence me needing to know the actual answer as I have some time to do the work this weekend.
Thanks to the other posters. Even though your replies are not very helpful, they are at least entertaining.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 494 times
PostPosted: Fri Feb 01, 2008 9:17 pm Reply with quote
Can't see your problem, I gave a direct answer to your question icon_confused.gif
Back to top
 Alert Moderators
blondini
from United Kingdom
PostPosted: Fri Feb 01, 2008 10:00 pm Reply with quote
This may help. http://www.ukcopperboard.co.uk/literature/pdfs/Installation-Tips/Domestic-gas-installation-testing.pdf If it is incorrect in any way I am sure someone will say so.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 335 times
PostPosted: Sat Feb 02, 2008 9:17 am Reply with quote
That link quotes a maximum joist notching depth of D/6, but building regs recommend a maximum notching depth of D/8.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 936 times
PostPosted: Sat Feb 02, 2008 9:44 am Reply with quote
THe Copper Development Association is there to sell copper, not tell you how to do gas work.
Their paper is WRONG AND INCOMPLETE. DO NOT FOLLOW IT.
There is more to installing gas pipework than spacing the clips. You have to know all there is otherwise you'll get something wrong.
You don't know all the rules therefore you aren't competent therefore it's illegal for you to install pipework to be used for gas.
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 234 times
PostPosted: Sat Feb 02, 2008 9:54 am Reply with quote
Call me cynical if you like but your original post smacks of a DIY install. No truely professional ŁORGI installer would agree to the customer hanging the boiler let alone running the gas pipework and then sign it off as his own work. icon_rolleyes.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
22mm Copper Pipe (Heating) Mount Spacing 5 640 Fri Jul 11, 2008 5:51 pm
CH & water installation - pipe spacing & yorkshire f 6 140 Sat May 28, 2011 6:09 pm
Pipe clip spacing 8 5860 Sat Mar 13, 2010 11:43 pm
Bath tap hole spacing 4 1180 Fri Mar 27, 2009 9:53 pm
Extractor fan vent - boiler flue spacing 3 920 Sun Aug 31, 2008 12:48 pm
DIYnot
