plugwash said:2 red and 2 blue sounds wrong/dodgy
can you remember how the original switch was wired
plugwash said:what color was this "earth" wire
did you by any chance assume some yellow wires were earth?!
earth in british house wiring is done through bare cores which are sleeved with green/yellow sleeving
also what is the wiring like at the light fitting and at the wall switch
sorry its hard to be more helpfull but we can't really help until we have figured out wth is going on with your wiring
let this be a lesson to note down the connections before removing anything
I doubt that - light switches very rarely have a neutral present, just live and switched live. What colours are the wires?DIYBABY said:tHE EARTH IS DEFINATELY THE EARTH WIRE.
i HAVE LOOKED AT THE WIRING IN THE MAIN LIGHT SWITCH AND THERE IS JUST 1 LIVE , 1 NUETRAL AND IT IS EARTHED
It never rains but it pours. Try tightening it up first - that can sometimes break the seal.DIYBABY said:i CAN'T UNDO THE LIGHT FITTING AT THE CEILING IT IS JAMMED STUCK. I ASSUME YOU JUST UNSCREW IT BUT THE WHOLE UNIT TURNS THEN GETS STUCK AND I AM AFRAID TO FORCE IT
ban-all-sheds said:I doubt that - light switches very rarely have a neutral present, just live and switched live. What colours are the wires?DIYBABY said:tHE EARTH IS DEFINATELY THE EARTH WIRE.
It would be very useful to know which wires are live at each switch, and if any run between the two. As well as failing to make notes when you removed the old switch, have you also failed to equip yourself with one of the essential tools for doing work like this, i.e. a multimeter?
And BTW - please stop SHOUTING!
If you want to work on your electrics, a multimeter becomes a "normal" household tool, just like the screwdrivers you use to gain access to the cables, and the wire cutters and strippers you use to prepare them.DIYBABY said:I havn't any equipment except a screwdriver, and 'normal' household tools.
That's what you had at the pull-switch. What's at the other switch, the "main" one as you call it?The wires are 2 blue and 2 red and 1 earth.
