Joined: 22 Jul 2004 Posts: 10 Location: United Kingdom Thanked: 0 times
Posted: Sun Aug 22, 2004 4:21 pm Post Subject:
Cosumer unit
I intend to replace my existing wired fuse consumer unit, can anyone please advise what the advantages or disadvantages are in using a 12 way split load (MK) unit, Am I correct in thinking that only one bank of MCBs are protected by the RCD ?. If so how would you decide what bank of MCBs to use for what circuits ie. ring mains, cooker circuit,lighting circuit exterior power etc
I cannot find anything in the wiring regs to indicate acceptable distance a socket outlet should be located from a kitchen sink ?
Many thanks for any advice you can offer
Joined: 29 Sep 2003 Posts: 2205 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Sun Aug 22, 2004 7:09 pm Post Subject:
ZenStalinist wrote:
Cookers and immersion heaters are a disputed territory.
They seem to be, but there are no particularly good reasons why they should. As long as your circuit Zs will allow the protective device to meet the disconnection times you should be fine and 60898 MCB's will all operate inside 0.4 secs if the circuit is designed correctly.
Joined: 27 Aug 2003 Posts: 21980 Location: London, United Kingdom Thanked: 78 times
Posted: Mon Aug 23, 2004 7:34 am Post Subject:
Are they? I thought it was pretty undisputed that they don't need to be on the RCD side, and that putting them there is often a bad idea because of earth leakage.
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Posted: Mon Aug 23, 2004 8:09 pm Post Subject:
plugwash wrote:
frankly if something trips an rcd its probablly due for replacement anyway
Cooker elements can get condensation in that disappears almost as soon as they are powered up - it doesn;t make them unsafe, but it sure as hell can trip an RCD.
Quote:
do you
put everything on rcd except stuff that should not or must not be on rcd
Quote:
put everything on non-rcd except stuff that should or must be on rcd
Joined: 15 Aug 2004 Posts: 729 Location: United Kingdom Thanked: 5 times
Posted: Wed Aug 25, 2004 7:54 pm Post Subject:
Immersion and RCD
I even ran a 10.0. sq.mm. Earth bonding cable straight from my copper Immersion heater Cylinder to my fuse box - even though the immersion itself has it's own earth core in it's supply cable - you can't ever be TOO SAFE where electrics and water mix !!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
