DIYnot
Local | Network
   DIYnot > Forums
Local | Network
connecting to 1/2" Galvanised steel
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Redhotferrari
from United Kingdom
Thanked: 8 times
PostPosted: Tue Mar 04, 2008 12:16 pm Reply with quote
The rising main in my house is galvanised? steel, 1/2" and I want to change and move the stopcock slightly, changing the pipework after the stopcock to 15mm copper.
Does anyone know what connectors to use for attaching to the steel (compression hopefully) then changing to 15mm after?
Also, will it be ok to cut the existing steel with a hacksaw as I assume pipesplice wont fit this?
Many thanks in advance.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2522 times
PostPosted: Tue Mar 04, 2008 12:27 pm Reply with quote
Most people would only make a connection to a threaded piece of steel pipe.
Its not normal to try to use a compression fitting and there are none made for that specific purpose that I have ever heard of in the smaller sizes. Some of the rubber seal leadlocks MIGHT fit some steel but it would not be advisable.
Just use the existing screwed end!!!
Anything else at your own risk!
Tony
Back to top
 Alert Moderators
Redhotferrari
from United Kingdom
Thanked: 8 times
PostPosted: Tue Mar 04, 2008 12:58 pm Reply with quote
Thanks Agile, obvious question coming next!
As its old would the thread be a normal 1/2"? Is there a connector for the threaded end with a compression the other end as a coupling for the new 15mm?
The trade center mentioned asomething called a Johnson fitting? But cant find one on a Google search
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2522 times
PostPosted: Tue Mar 04, 2008 1:03 pm Reply with quote
Standard 1/2" female to 15 mm compression adapter.
I think the British pipe threads were around since the turn of the last century. Probably even before Doitall was born ?
Tony
Back to top
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 33 times
PostPosted: Tue Mar 04, 2008 1:10 pm Reply with quote
Assuming it is 1/2 BSP (pipe will be about 3/4 o/d) , and assuming it has a threaded end then something like:
http://www.screwfix.com/prods/71308/Plumbing/Compression-Fittings/Yorkshire-Kuterlite-Female-Coupling-612-15mm-x#
Will take you to 15mm copper. I would not want to continue in steel to a different stop tap location.
If you cut the threaded end off the steel you may have problems getting a secure connection unless you re-cut the thread on the end.
Any plumbers merchant will have something similar on the shelf.
Back to top
 Alert Moderators
LeeC
from United Kingdom
Thanked: 2216 times
PostPosted: Tue Mar 04, 2008 11:04 pm Reply with quote
Viking Johnson is what they were refering too.
Back to top
 Alert Moderators
jay1
from United Kingdom
Thanked: 4 times
PostPosted: Tue Mar 04, 2008 11:14 pm Reply with quote
u can get a fitting which u can cut the steel pipe anywhere and tighten up, its similar 2 a compression fittting only slightly bigger
Back to top
 Alert Moderators
WDIK
from United Kingdom
Thanked: 55 times
PostPosted: Tue Mar 04, 2008 11:23 pm Reply with quote
Tony[/quote]
end of
tony is right
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Galvanised Steel Water Tank Value 3 121 Sun Feb 06, 2011 9:58 pm
Galvanised steel water storage tank in loft 5 120 Mon Jul 11, 2011 12:52 pm
Galvanised Steel Soil / Stack Pipe - Fernco Fittings 2 680 Fri Nov 02, 2007 12:16 pm
steel galvanised cold water tank leaking 14 160 Sun Feb 26, 2012 9:20 pm
Leaking old style galvanised tank - HELP!!! 11 680 Tue May 09, 2006 5:27 pm
DIYnot
