DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fixing a pedestal sink to wall, where 1 rawplug seems loose
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
compact
from United Kingdom
Thanked: 1 time
PostPosted: Mon Mar 31, 2008 1:31 pm Reply with quote
Hi
I have a plasterboard wall, where I drill two holes and placed pasterboard rawplugs in them.
The first hole hit a wood baton, so that is as secure as anything.
The second was just plasterboard.
I inserted both plugs, then tiled the splash back.
As I come to fit the sink (with pedestal), one of the plugs seems loose.
What should I do?
1) Push plug through and try and get a second one through? (possibly having to widen the hole in the tile)
2) Lots of pink grip and 1 firm plug and pedestal?
3) Take off tiles, cut a hole and try to fix in some wood to the batons, to act as an anchor? (this one does seem the most secure, but hardest).
What do you think?
Back to top
 Alert Moderators
Bilioustrumpstaine
from United Kingdom
Thanked: 4 times
PostPosted: Mon Mar 31, 2008 5:38 pm Reply with quote
I would try using a good quality fixing on the side that is loose such as these.
http://www.wickes.co.uk/Fixings-Specialist/Cavity-Fixers/invt/510048
If that fixing works for you by the time you have sealed the back of the basin with silicone you will have a sturdy fix, The weight of the basin should be on the pedestal and the fixings just to stop it coming away from the wall.
Back to top
 Alert Moderators
compact
from United Kingdom
Thanked: 1 time
PostPosted: Tue Apr 01, 2008 8:34 am Reply with quote
That could work.
I drill a size 10 hole and put in a plasterboard plug.
/edit/ Just noticed it is size 8 drill bit, hopefully I can find a larger one/
hopefully this will be large enough to fill that hole and sit firmly in it.
Will have to drill a larger hole in the tile to slot it in.
But cheers for the advice.
Back to top
 Alert Moderators
Bilioustrumpstaine
from United Kingdom
Thanked: 4 times
PostPosted: Wed Apr 02, 2008 6:57 pm Reply with quote
The fixings come in various sizez.
Back to top
 Alert Moderators
reece-o
from United Kingdom
PostPosted: Fri Apr 11, 2008 12:51 pm Reply with quote
you'll need one of those guns to work the cavity fixing - otherwise it'll just spin round and around and tear you a bigger hole in your plasterboard.
/been there
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Semi Pedestal Sink Fixing in place 12 2320 Wed Dec 10, 2008 4:27 pm
wickes babel pedestal - how to fix to the floor? 2 100 Mon Jul 16, 2012 10:30 am
Loose Bathroom Sink 3 720 Wed Oct 08, 2003 6:30 pm
One of two screws holding my sink in place has gone loose 8 160 Sun Jan 15, 2012 7:05 pm
Loose rawl plug fixing 5 1940 Sat Nov 14, 2009 7:13 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
