Moving socket sideways
8 Apr 2008
Suffolk
I want to move a ring final socket sideways by about 200mm. The existing cable run comes vertically down the wall. Should I crimp a 2.5mm extension cable, joined at the existing box and use a blanking plate over, or can I heat shrink the crimps and bury the lot in the wall?.
I realise that by doing the latter, the position of the vertical cable run will not be identified by an accessory.
Would appreciate any comments on this.
I want to move a ring final socket sideways by about 200mm. The existing cable run comes vertically down the wall. Should I crimp a 2.5mm extension cable, joined at the existing box and use a blanking plate over, .
Yes you can do this
No you can't do this . for the reason that you have identified.
is there a reason you cant leave existing socket and add new socket
It sounds like there is only one cable (he didnt say cables) going to the old socket. So it is probably a spur. If he added another then it would be a spur off a spur.
god taylor you are sharp this time in the morning i think i will have cup of tea
Ah - but is he as sharp as he thinks he is?
The OP said it was a ring, and he said existing cable run, not cable.
Taylor might well be right, but not necessarily...
No sugar in mine, and not too much milk... ;)
