Joined: 13 Sep 2004 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Mon Sep 13, 2004 3:52 pm Post Subject:
Conduit and Wall box depths
Maybe this is a plastering question but....
I have a new outbuilding that is awaiting the plaster; leaving time for me to carry out the wiring.
My question is what trunking/conduit is best to use so that the there is enough depth to cover with plaster. Also what depth do I need to leave the plasterers to ensure the conduits etc are covered...?
How proud should the boxes be for the light switches, sockets etc
The wall is Breeze (Fen-Light) block with concrete floor.
Does anyone have a ny links on this particular area....
Joined: 29 Sep 2003 Posts: 2205 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Mon Sep 13, 2004 4:15 pm Post Subject:
Use 'top hat' galvanised capping, fixed with galvanised nails or rust-proof screws directly over your cables. It comes in various widths and is available at any electrical wholesaler, or you can get it at most builders merchants and DIY sheds. Whether wet plaster or dot-and-dab this will be perfectly acceptable to the plasterer. (To do a really pucker job you should turn over the sharp cut ends of the capping)
Ask your plasterer about the depth for galvanised back boxes. If' he's dotting and dabbing he may be happy for you to fix 25mm deep boxes directly to the wall surface, but otherwise you should sink them to about half their depth. You should be able to leave 16mm light switch boxes at their full depth.
Joined: 11 Jan 2004 Posts: 16485 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Tue Sep 14, 2004 1:22 am Post Subject:
My worst nightmare was a three gang switch in a 16mm box, AND all of them were two way, with 5 conductors in each switch. ^&*(^$ knows how the guy did it. I had to admit defeat and tell the guy it needed a deeper box. All he said was "it was all right till you came...."
Well it wasn't cos the switching did not work properly.
Joined: 14 Sep 2004 Posts: 18 Location: United Kingdom Thanked: 0 times
Posted: Tue Sep 14, 2004 10:47 am Post Subject:
Can someone tell me is capping a regulation or is it just good practice? I know you need it if the cable runs at an angle but do you need it if it runs straight and within 150mm of a corner or the ceiling??
Posted: Tue Sep 14, 2004 10:59 am Post Subject:
Good practice. And outside the permitted zones capping is not adequate protection. Cables outside permitted zones ( http://www.tlc-direct.co.uk/Book/4.4.1.htm ) must be at least 50mm deep or mechanically protected against penetration by nails or screws.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
