DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ideal LXFF260 not igniting
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
nova1
from United Kingdom
PostPosted: Wed Apr 30, 2008 10:12 pm Reply with quote
Help please.
Have a problem an Ideal LXFF 260 boiler not igniting. Thermostat on full, water and heating programmer on Have checked through the fault find flowchart and so far
fan is working OK (replaced about 18 months ago)
boiler thermostat set to maximum and mains switch on
Ignition electrode is sparking BUT pilot does not light
Pilot injector is clear
Therefore I assume that there is no gas reaching the pilot - what do I need to check next.
For info the gas valve is a Honeywell VR4601A/A1036
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 804 times
PostPosted: Wed Apr 30, 2008 10:15 pm Reply with quote
If you have 240vAC at GV1 on the pcb then it is a faulty gas valve.
RGI job only though to replace, especially on these as they can be a pain in the ar*e
Back to top
 Alert Moderators
nova1
from United Kingdom
PostPosted: Wed Apr 30, 2008 10:41 pm Reply with quote
Thanks Dave, I'll check voltage on PCB.
By the way - waht is RGI??
Cheers
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Thu May 01, 2008 5:54 am Reply with quote
Or if your getting to 240 at pilot solenoid just change that ,no need to touch gas it just held on by a clip
Back to top
 Alert Moderators
nova1
from United Kingdom
PostPosted: Thu May 01, 2008 12:23 pm Reply with quote
Hi Dave
Just checked with multimeter and have 233V at GVI when the boiler is on and pilot igniter clicking away.
Assume it needs a new gas valve so I will have to call in my local friendly Corgi guy. - Any idea what a reasonable charge is for this type of work??
Back to top
 Alert Moderators
superdupergasman
from United Kingdom
PostPosted: Thu May 01, 2008 2:13 pm Reply with quote
if you can change the pilot solenoid then 10 mins
if you need the whole valve then 90mins as said they are a pain in the backside
Solinoid maybe 20 Gas valve 100 perhaps??
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 804 times
PostPosted: Thu May 01, 2008 2:16 pm Reply with quote
Changed one last week, gas valve, 198 + VAT total.
Back to top
 Alert Moderators
nova1
from United Kingdom
PostPosted: Fri May 02, 2008 11:31 am Reply with quote
Thanks for all the help, going to check pilot solenoid first then call out the local Corgi guy if gas valve needs changing.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ideal HE24 F L not igniting 7 240 Sun Apr 17, 2011 6:31 am
Ideal Iscar combi not igniting 3 80 Sat Dec 06, 2014 12:46 pm
Ideal Mini Not Igniting 6 60 Mon Sep 12, 2011 3:24 pm
Ideal Mexico RS55 Boiler not fully igniting 5 80 Wed Sep 14, 2011 2:51 pm
Ideal C28 not igniting 7 320 Sun Jan 04, 2009 12:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
