DIYnot
Local | Network
   DIYnot > Forums
Local | Network
types of bricks
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
briwire
from United Kingdom
Thanked: 3 times
PostPosted: Sat May 10, 2008 12:24 pm Reply with quote
I'm preparing to build a small garden wall. Nothing major, but I'm puzzled by the different type of bricks available.
I've had a walk round a few builders merchants and seen Engineering bricks which are smooth on all sides. Are these used where they can't be seen for cheapness?
I want to use ones similar to those on the house which have a texture to them.
Anyone got a brief description of each type of brick and where they should be used?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Sat May 10, 2008 12:56 pm Reply with quote
i don't know what it is in the manufacturing process that makes one particular brick cost more than another to produce.
red engineering bricks are produced in their millions so are obviously less expensive. staffy blues are also an engineering brick but cost a lot more.
L.B.C. bricks are tat and very porous but cost a bomb. these are practically useless in a garden wall.
some bricks readily absorb water where others don't
an engineering brick for example is rather hard and non porous so is ideal for below dpc, close to the ground and for finishing off (coping brick) a garden wall. or anywhere that is exposed to a lot of moisture or water.
so, you want a hard brick close to the ground and a hard brick to finish off. i guess you can use what you like in between.
i would not recommend anything that is particularly porous for a garden wall, particularly if it were retaining.
harder bricks are more difficult to lay in cold wet weather and very porous bricks are difficult to lay in warm dry weather. those with moderate suction i.e. a London brick (l.b.c.) are a piece of cake to lay in whatever conditions. icon_wink.gif
Back to top
 Alert Moderators
briwire
from United Kingdom
Thanked: 3 times
PostPosted: Sat May 10, 2008 7:56 pm Reply with quote
If I'm building a double thickness garden wall, is it the done thing to use a hard engineering brick on the retaining surface where there will be constant wet soil in contact with it, and a decorative outer where it will be seen?
I want something reddish with a textured finish, similar to the house. I've had a look on B&Q, and they do one called Hartshill red, which looks similar to what I am after.
Back to top
 Alert Moderators
tawelfryn
from United Kingdom
PostPosted: Sat May 10, 2008 8:57 pm Reply with quote
Agree with everything you say Noseall, but LBC's are murder in hot sunny conditions, you have to be quick with the jointing, otherwise they are terrible to joint, worth soaking them down with water before laying when its warm
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Sun May 11, 2008 8:56 am Reply with quote
aah, but tawelfyn - are you a frog up or a frog down kinda guy. icon_lol.gif
frog up allows for a decent volume of muck and helps with all that suction. i agree, they are in the upper bracket of suction and do need a good dousing in the summer. icon_wink.gif
there are worse though....
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Concrete blocks, 2 types? 3 80 Tue Aug 14, 2012 6:21 pm
Garage doors - sizes and types 6 140 Thu Feb 24, 2011 5:23 pm
Insulation Types : Glass wool or Bubble foil stuff 8 1220 Tue Nov 11, 2008 3:17 pm
Types of lintels 6 180 Sat Mar 07, 2015 3:56 pm
Quick question, is it possible to mix insulation types? 6 200 Thu Mar 26, 2015 9:06 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
