DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Is this a common sight?
Goto page 1, 2  Next
Author Message
uselessFCUK
from United Kingdom
PostPosted: Mon May 26, 2008 4:38 pm Reply with quote
(Also, is this TN-S? icon_redface.gif )
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 211 times
PostPosted: Mon May 26, 2008 4:40 pm Reply with quote
Looks like TNS. A picture of the cutout whole would be nice.
Its tar leaking from the cutout. Call the DNO, they'll replace it FOC i think.
Back to top
 Alert Moderators
bongos
from United Kingdom
Thanked: 77 times
PostPosted: Mon May 26, 2008 4:42 pm Reply with quote
The gloopy stuff is tar from your service head/supply cable and means you need to put a call into your DNO to get them to come and sort it.
As for TN-S? I dunno - it lookslike there may be an old earth taped to the sheath there in a sort of crude TN-S. I'm sure the DNO would sort that for you too at the same time.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 187 times
PostPosted: Mon May 26, 2008 4:44 pm Reply with quote
Crude TN-S?
Looks like apretty standard lead sheathed TN-S to me. That assumes your installation is connected to the provided terminal.
As for the tar, it is an all to common sight. It could easily have been like this from day one. The DNO are unlikely to do anything unless there is signs of overheating.
Back to top
 Alert Moderators
uselessFCUK
from United Kingdom
PostPosted: Mon May 26, 2008 5:09 pm Reply with quote
Install circa 1968
Meter dated 1989
CU just dated!
Thanks. UF
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 187 times
PostPosted: Mon May 26, 2008 6:08 pm Reply with quote
Defo TN-S.
Tails *look* to be 16mm with a 10mm earth, The earth should be 16mm to comply to the current regs, but at 10mm it is retrospectively fine until you have a CU upgrade or similar. As a point of note, 6mm earths where more common.
Do you also have a second CU? You have some newer looking tails going from left to right (the grey ones). These look to be taken from the top of the incomer of the old CU - not a great practice.
Does not look like there is too much to be concerned with when thinking of immediate danger etc, but could do with updating.
Have you checked your bonding?
Back to top
 Alert Moderators
regsmyth
from United Kingdom
Thanked: 28 times
PostPosted: Mon May 26, 2008 8:52 pm Reply with quote
Lectrician wrote:
As for the tar, it is an all too common sight. It could easily have been like this from day one. The DNO are unlikely to do anything unless there is signs of overheating.
Strange you should say that, when I saw the first photo, I thought "that could be a sign of overheating".
Of course I defer your greater experience, but on a recent thread there was a photo of a burnt out cu, and one of the tarry cables had started to "bead up" on the surface, presumably as a result of heat.
Also, there's no dust on the tar so it could be fresh.
Back to top
 Alert Moderators
uselessFCUK
from United Kingdom
PostPosted: Mon May 26, 2008 10:50 pm Reply with quote
Tails go off to shower's RCBO.
Back to top
 Alert Moderators
industryspark
from United Kingdom
Thanked: 8 times
PostPosted: Tue May 27, 2008 7:14 pm Reply with quote
Quote:
regsmyth wrote;
i would have to agree with lectrician here, was at a house doing some work couple of years back now when the YEDL guy turned up to do their bit, i enquired about the black tar ooze at this certain property and the guy seemed unconcerned and said that its quite common to see this, he said it never concerned him unless there were other indications that something was wrong.
regards.
Back to top
 Alert Moderators
uselessFCUK
from United Kingdom
PostPosted: Tue May 27, 2008 9:43 pm Reply with quote
Well what exactly is the black tar stuff?
Is it used as a seal of some sort?
Back to top
 Alert Moderators
333rocky333
from United Kingdom
Thanked: 200 times
PostPosted: Tue May 27, 2008 10:25 pm Reply with quote
Seen it a lot in commercial sites ,usually a blob off it built up on the floor.
Suppose it is some sort of insulator maybe.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1089 times
PostPosted: Tue May 27, 2008 10:35 pm Reply with quote
the tar is clearly black and shiny, so it is new and fresh, or it would be coated with dust and cobwebs.
you mention an electric shower...
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 187 times
PostPosted: Wed May 28, 2008 6:30 am Reply with quote
I see cobwebs on the tar.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1089 times
PostPosted: Wed May 28, 2008 6:35 am Reply with quote
in this one there is a fresh clean dribble
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1339 times
PostPosted: Wed May 28, 2008 8:55 am Reply with quote
Fnarr fnarr
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Visually Impaired / Severely Sight Impaired 6 240 Wed Dec 29, 2010 10:53 pm
which light for common parts? 2 200 Tue Feb 03, 2009 6:28 pm
Dimmer Switch has only L1 & L2 - No Common or ~ symbols- 4 360 Mon Oct 13, 2008 4:14 pm
MPB - regs or common sense? 85 2480 Mon Feb 21, 2011 6:10 pm
RCD wiki + Common Misconceptions about RCDs 120 2140 Wed Sep 07, 2011 1:02 pm
DIYnot
