DIYnot
Local | Network
   DIYnot > Forums
Local | Network
baxi 105 he fan/flue fault
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
willroy
from United Kingdom
PostPosted: Thu May 29, 2008 10:03 am Reply with quote
HI first post here goes.House is currently unoccupied .Boiler was serviced and was working ok.Turned preheat off on hw as nobody was staying in the house.Anyway turned tap on a few weeks later no hot water.Tried heating same.Went to boiler noticed when heat was being asked for by either tap or radiators the 50 degree light would flash meaning fan/flue fault.The boiler is approx 3 years old and hasn't missed a beat till now.Looked at various posts regarding this fault and can't make my mind up what to look for.When heat is asked for the fan above spins up then after a few seconds the fault appears.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3434 times
PostPosted: Thu May 29, 2008 11:34 am Reply with quote
Could be a faulty PCB.
But it could also be a fan/flue/APS problem but all of those aspects should be investigated by a competent CORGI engineer.
Tony
Back to top
 Alert Moderators
willroy
from United Kingdom
PostPosted: Thu May 29, 2008 12:19 pm Reply with quote
Thought about the aps but most common seems the pcb replacement for a new one.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3434 times
PostPosted: Thu May 29, 2008 12:20 pm Reply with quote
A competent boiler engineer diagnoses the actual fault rather than changing an expensive part "because they sometimes fail".
Back to top
 Alert Moderators
willroy
from United Kingdom
PostPosted: Thu May 29, 2008 1:17 pm Reply with quote
easier said than done where i live .I am a mechanical /electrical engineer by trade .Can diagnose most faults in my line as i have an abundance of spare parts.I know a few plumbers /so called engineers who have come out to boilers before with no luck costing friends a fortune.Thanks anyway for your help will check aps switch is switching first if ok will check pcb relays
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3434 times
PostPosted: Thu May 29, 2008 1:37 pm Reply with quote
Merely finding a fault by repetitively changing parts is not really "diagnosing" the fault.
We call them "parts changers". They are mostly employed people as independents cannot afford to change expensive parts in case they are not the problem!
Tony
Back to top
 Alert Moderators
willroy
from United Kingdom
PostPosted: Thu May 29, 2008 1:44 pm Reply with quote
I understand where your coming from but decent boiler enginneers where i live are like rocking horse s**t.
Back to top
 Alert Moderators
LUNAT
from United Kingdom
Thanked: 22 times
PostPosted: Fri May 30, 2008 8:40 pm Reply with quote
HI
APS faulty= common fault on these boilers.
Back to top
 Alert Moderators
willroy
from United Kingdom
PostPosted: Sat May 31, 2008 5:03 pm Reply with quote
If i short the terminals to make a circuit should pinpoint fault ie if boiler fires up aps switch if not something on pcb
Back to top
 Alert Moderators
Trouble666
from United Kingdom
Thanked: 2 times
PostPosted: Sat May 31, 2008 6:37 pm Reply with quote
If the fans running and the boiler then goes to lockout, I would suspect a faulty APS myself; But again, like someone said in this thread earlier, a competent engineer would use a multimeter to diagnose through faultfinding-
If your going to chuck parts chuck an APS before chucking a PCB!
Back to top
 Alert Moderators
willroy
from United Kingdom
PostPosted: Mon Jun 02, 2008 8:59 pm Reply with quote
Had a good look at it today.checked out aps looked ok.Has a common supply with normally open and normally closed contacts.Power was going to aps but didn't look like it was switching when fan gets to full speed.Checked with meter when fan at full speed hey presto boiler lights up .Removed meter boiler shuts down.Faulty aps switch i hope .getting new one tomorrow
Back to top
 Alert Moderators
willroy
from United Kingdom
PostPosted: Tue Jun 03, 2008 6:18 pm Reply with quote
fitted new aps today working great.Thanks for all your help
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi 105e fan/flue fault 18 340 Mon Dec 26, 2011 10:39 am
Baxi 105e No CH or HW Flame Failure and Fault on Flue or Fan 17 9460 Thu Jan 20, 2011 9:56 pm
Baxi 105 Fault on Fan or Flue 7 140 Wed Oct 08, 2014 12:24 pm
Baxi 105e Fan/Flue fault led flashing 27 29020 Mon Jan 29, 2007 9:06 pm
Baxi 105 flue/fan fault 2 220 Sat Feb 13, 2010 12:16 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
