DIYnot
Local | Network
   DIYnot > Forums
Local | Network
sealant used in Hob recess
Author Message
nichos
from United Kingdom
PostPosted: Tue Jun 03, 2008 7:38 am Reply with quote
The ceramic hop instruction says use a sealant BUT NOT SILICON round the inside of the cut in worktop.
B&Q etc. all say they do not have a Non Silicon type.
Can you advise please?
thanx nick
Back to top
 Alert Moderators
davelx
from United Kingdom
Thanked: 37 times
PostPosted: Tue Jun 03, 2008 9:18 am Reply with quote
Back to top
 Alert Moderators
Veglen
from United Kingdom
PostPosted: Tue Jun 03, 2008 10:35 am Reply with quote
From memory, ceramic hobs are generally supplied with a dense foam seal.
Similar to the ones used on door and window frames as a draft proofer. You could probably use the type that's on a roll and sticks on the door frame to stop drafts when the door closes against it. The dense foam would probably be best. Not the cheap stuff!
The idea is that the seal is stuck to the underside of the ceramic hop around the edge. When the hob is placed into position the seal compresses against the worktop under the weight and is clamped down. This causes it to seal and prevents any movement.
Hope that makes sense!
V
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 335 times
PostPosted: Tue Jun 03, 2008 12:05 pm Reply with quote
If you use silicon sealant it will probably stick like the proverbial to a blanket, so if you try and lift the hob out for any reason you end up with two halves of a hob before the seal breaks.
And there endeth the guarantee.....
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 150 times
PostPosted: Tue Jun 03, 2008 12:30 pm Reply with quote
Plumbers mait is good for this
Back to top
 Alert Moderators
Richard1
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jun 03, 2008 1:04 pm Reply with quote
I think most of you have misunderstood the poster, although in all fairness this is more akin to kitchen fitting.
The manufactures of the worktops usually request that cut outs in worktops should be sealed, normally this is achieved with either upva wood glue or silicon, this is usually applied to the raw edge of the worktop prior to fitting the hob and should be allowed to dry before fitting the appliance
Back to top
 Alert Moderators
nichos
from United Kingdom
PostPosted: Tue Jun 03, 2008 3:20 pm Reply with quote
Thanx you all, probably the last sugestion is as applicable as any, except for the SILICON.
The others are somewhat vague.
The Screwfix you give says "30% stronger than traditional silicone. Mould-resistant and waterproof".
Anybody used tis one:- code 45463 "No Nonsense Intumescent Sealant 310ml 310ml. Interior fire retardant and acoustic Sealant. Excellent acoustic properties. Paintable, with non-slump properties. Fire-rated to BS476 Part 20 / 22.
The cut out instruction for the sink said paint the raw cut surface & shows a brash, BUT the instruction for the Hob cut out shows the "gun & sealant tube" running against the cut surface, sayng sealant BUT NOT SILICON.
Has anybody used Plumbers mait for hobs? if it will not burn out with the extra hob heat, it would be the easiest to apply.
nick
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 150 times
PostPosted: Wed Jun 04, 2008 7:01 am Reply with quote
I have used plumbers mait. I contact the manufacture to find the temperature that it was ok at. Its been in use for 3 years now.
If you use silcone, you will have problems getting the hob out, should you need to for repairs.
I worked in domestic appliances developement for over 15 years, our hobs were always supplied with a foam strip.
My new hob was supplied with foam tape, but has it was on a tiled surface, the tape was not thick enough, hence using plumbers mail.
Back to top
 Alert Moderators
nichos
from United Kingdom
PostPosted: Fri Jun 06, 2008 9:15 am Reply with quote
many thanx, will use P.mait. nick
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
recess lights: 6cm space only. 11 760 Fri Jan 04, 2008 9:16 pm
Best way to recess plug sockets? 45 3940 Sun Mar 25, 2007 12:37 am
Weather Proof Recess Lights 3 321 Wed Jun 18, 2008 3:44 pm
Single recess and double sockets / converters 4 140 Sat Jan 14, 2012 7:46 pm
Bathrom Wall Recess and Cupboard Light 7 60 Wed Mar 14, 2012 9:29 pm
DIYnot
