DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Adding extra support when fitting bath
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
dummer
from United Kingdom
PostPosted: Tue Jul 01, 2008 4:04 pm Reply with quote
I will soon be fitting a new acrylic bath. My sister recently had a similar bath fitted by a plumber, and he used expanding foam beneath the bath to add extra support. He built a 'frame' beneath the bath and then 'filled it' with expanding foam. The bath certainly seems to be far more solid than just using the metal support legs provided, and I guess the water would stay hotter, longer. Has anyone used this system, and what are the pitfalls (other than getting foam everywhere!!
Back to top
 Alert Moderators
wiggikins
from United Kingdom
Thanked: 13 times
PostPosted: Tue Jul 01, 2008 4:27 pm Reply with quote
Just fit a 2x1 batten along length/end of bath that should be adequate in most cases!
Back to top
 Alert Moderators
dummer
from United Kingdom
PostPosted: Tue Jul 01, 2008 5:09 pm Reply with quote
Thanks. I will be having an over bath shower, and wonder if the extra support beneath the bath might be useful when I'm standing in it, to prevent any creaking or movement.
Back to top
 Alert Moderators
wiggikins
from United Kingdom
Thanked: 13 times
PostPosted: Tue Jul 01, 2008 5:16 pm Reply with quote
It will help!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Bath support frame-tips 7 8960 Wed Dec 09, 2009 2:14 pm
bath support frame- can I cut the support bars down ok? 2 80 Sun Feb 17, 2013 9:57 am
HELP! Shower supply (tapped off under bath) needs support 10 120 Tue Apr 02, 2013 7:58 am
Bath installed with no feet/support 5 780 Fri May 11, 2007 1:07 am
Bath support "W" type 3 360 Fri Mar 13, 2009 3:42 pm
DIYnot
