What do you experienced chaps do in the panel when there are loads of DC supply sensors on the system and it makes the SINGLE TERMINAL DC output too busy, I usually use a 5A terminal block, make off all the DC supply wires into that, then run a bigger single cable, from the terminal block to the DC output of the panel. Anyone got a better suggestion
