DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ideal Mini C24 cold inlet problem / low pressure
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
dj51hog
from United Kingdom
PostPosted: Wed Jul 23, 2008 11:34 am Reply with quote
I have a 2 year old Ideal Mini C24, just out of warranty.
The water pressure is at 0 bar and subsequently the boiler is firing but cuts out after a short period of time.
I have located the cold water inlet, which appears to have been installed with a 'blue' valve below the boiler unit, however when i open the valve the pressure does not increase? and i cannot hear any water flowing into the boiler either? the water supply is okay in the rest of my property? the valve is quite stiff to operate and i am turning it clockwise to open it.
I am not sure why the systems pressure is not increasing? and or water is not feeding into the boiler.
Any ideas/solutions would be appreciated.
Regards
dj
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1132 times
PostPosted: Wed Jul 23, 2008 12:33 pm Reply with quote
Have you got the right tap ? If it shuts off the water going through the boiler it's the wrong one!
If not see the faqs - filling loop.
FIrst check for a tap at the other end of the flexy hose - may be screwdiver operated.
Is your blue tap actually turning anything?
Often the metal parts go stiff, so the plastic turns on the shaft. Remove plastic via small screw and use a small spanner.
Back to top
 Alert Moderators
dj51hog
from United Kingdom
PostPosted: Wed Jul 23, 2008 12:51 pm Reply with quote
Thanks ChrisR
Am pretty sure I have the right tap as the diagram in the service manual labels it 'DHW Cold Inlet'.
I will try your suggestions tonight and get back to you.
best regards
dj
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1132 times
PostPosted: Wed Jul 23, 2008 12:58 pm Reply with quote
That's NOT the one you want!
Back to top
 Alert Moderators
powell30
from United Kingdom
Thanked: 129 times
PostPosted: Wed Jul 23, 2008 1:00 pm Reply with quote
No...you don't. DHW cold inlet......Domestic Hot Water.....a clue in the name.....it has nothing to do with your Central Heating circuit. The blue tap is an isolator. Test it. Turn it off and open a hot water tap....no water...isolated.
To fill your central heating system you use a filling loop designed to connect mains cold water to the sealed heating system. This will be by an external filling loop between cold mains and heating pipe or an integral system used on some boilers. Get your manual out and read how it's done or send a pic
Back to top
The following user says thank you to powell30 for this useful post:
MrspopsY (22 Oct 2011)
 Alert Moderators
dj51hog
from United Kingdom
PostPosted: Wed Jul 23, 2008 2:07 pm Reply with quote
apologies, I assumed the 'cold inlet' was used to top up the system, my mistake.
I have now identified the actual filling loop diagram, and it is actually a flexible hose that connects to the 'CH return', the filling loop is isolated using a stop valve at either end with a double check valve assembly in between. I will loosen the screws on both stop valves and hopefully i will be able to increase the pressure to around 1 bar as recommended by the service manual.
Thanks again for your assistance and patience, I will keep you posted.
best regards
dj
Back to top
 Alert Moderators
dj51hog
from United Kingdom
PostPosted: Thu Jul 24, 2008 7:46 am Reply with quote
Thanks all, as I have managed to re-pressurise the system to 1 bar, hooray. The isolator valve was installed without a 'plastic lever', so i got a spanner to open it.
Now however, when the boiler fires initially (for either CH or DHW) it burns for around 5-10 seconds and then cuts out, i then need to reset (using the reset button) and then it seems to run okay. It seems to do this on the initial ignition only, after the boiler has been idle for a while? but then after a reset it runs okay? hmm?
dj
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3598 times
PostPosted: Thu Jul 24, 2008 11:04 am Reply with quote
I assume that you are pushing the red button in the middle which is the ignition failure reset.
It may just be an adjustment required or something more involved. However I cannot give you any detailed advice as that requires a competent CORGI engineer.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ideal Mini C24 DHW alternates hot/cold 6 100 Tue Oct 25, 2011 7:18 pm
Ideal Mini C24 pressure rising on guage 3 3420 Sat Oct 28, 2006 8:24 am
Ideal mini 24 losing pressure fast 9 60 Tue Nov 06, 2012 9:29 pm
Ideal Mini HE C28 boiler problem 9 1220 Tue Jan 19, 2010 10:50 pm
ideal mini c32 problem.need help 4 720 Thu Sep 27, 2007 9:19 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
