DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Leaking radiator valve
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
johnkk
from United Kingdom
PostPosted: Wed Aug 06, 2008 5:43 pm Reply with quote
I have a leak round the spindle of a rad valve, which stops if I turn it off.
It is a Belmont (at least 30 years old). Can I replace the o-ring without draining down? I would be grateful for information how to do it.
John
Back to top
 Alert Moderators
wiggikins
from United Kingdom
Thanked: 13 times
PostPosted: Wed Aug 06, 2008 8:17 pm Reply with quote
Renew it!
Back to top
 Alert Moderators
lightning
from United Kingdom
Thanked: 175 times
PostPosted: Wed Aug 06, 2008 8:28 pm Reply with quote
Yes you can replace it without draining it down.
To find out what o ring you need take the plastic head off the valve to a plumbers merchant before you begin the work.
On the old valves i think the rings are green.new ones are red
Wrap a towel around the valve body and undo the spindle {left hand thread}
A little bit of water might leak out at first but as you continue to remove spindle the water pressure will seal the valve.
2 o rings are housed in grooves in the spindle.prise off the rings using a tip of a screwdriver ,lubricate the spindle with a smear of silicone grease.slide new rings into position and replace the spindle.
Back to top
 Alert Moderators
spacethegas
from United Kingdom
Thanked: 2 times
PostPosted: Wed Aug 06, 2008 9:17 pm Reply with quote
as lightning says.
but you've got to be brave to try it & be prepared if a problem was to occur.
belmonts were the rolls royce of rad valves of their time costing five times the price of any other.
Back to top
 Alert Moderators
buster52
from United Kingdom
PostPosted: Wed Aug 06, 2008 9:30 pm Reply with quote
something I used to do was to loosen the packing nut and cut a loop or two of cord insert it and re-tighten the packing nut, this will compress the original packing more and will work if the valve is not too worn
Back to top
 Alert Moderators
johnkk
from United Kingdom
PostPosted: Thu Aug 07, 2008 10:06 am Reply with quote
Thanks for your comments.
When you say undo spindle LH thread, do you mean open tap and keep going (i.e. turn actual spindle), or do you mean undo the nut round the spindle?
Is the nut LH thread?
Does the actual spindle(i.e the rod that the plastic cover fits on) actually come out?
Thanks, John
Back to top
 Alert Moderators
johnkk
from United Kingdom
PostPosted: Thu Aug 07, 2008 4:39 pm Reply with quote
Sorry if the last post is confused, but I would appreciate any clarification.
Thanks, John
Back to top
 Alert Moderators
youth
from United Kingdom
Thanked: 21 times
PostPosted: Thu Aug 07, 2008 7:12 pm Reply with quote
yes, nut normal thread ,undo anticlockwise and take off ,no water . spindle lefthand thread undo clockwise and remove slight water use towels and baking tray, a spring loaded valve will stop most of water as spindle is removed swop o rings with same colour red or green and replace everything in reverse
Back to top
 Alert Moderators
johnkk
from United Kingdom
PostPosted: Fri Aug 08, 2008 4:34 pm Reply with quote
Sorry to be thick about this, but if spindle is LH thread, does this mean that if you turn off hard the spindle will come out?
How do you tighten it up again without turning on the radiator?
Thanks for taking the trouble to answer daft questions,
John
Back to top
 Alert Moderators
youth
from United Kingdom
Thanked: 21 times
PostPosted: Fri Aug 08, 2008 8:36 pm Reply with quote
under normal use the nut stops the spindle coming out , when changing the o rings removing the nut allows the spindle to be withdrawn it may sound like witchcraft but it does work , 5 min job .just need right colour o rings
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 421 times
PostPosted: Fri Aug 08, 2008 8:41 pm Reply with quote
its a bit scary first time you do it, but they are the best valves well worth repairing.
Back to top
 Alert Moderators
johnkk
from United Kingdom
PostPosted: Sat Aug 09, 2008 4:28 pm Reply with quote
Thanks again, John
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 406 times
PostPosted: Sat Aug 09, 2008 4:55 pm Reply with quote
Not on a Belmont valve.
Back to top
 Alert Moderators
assured heating
from United Kingdom
Thanked: 26 times
PostPosted: Sat Aug 09, 2008 6:05 pm Reply with quote
Pegler do a kit for the belmont but its cheaper just to replace the whole valve icon_rolleyes.gif
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 406 times
PostPosted: Sat Aug 09, 2008 6:31 pm Reply with quote
Ye gods, Plumb Center charge 1.86 + VAT each for the replacement o-rings. icon_eek.gif That means I must have over 100 worth in my van. icon_razz.gif Best go and double check the alarm. icon_lol.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
My radiator is leaking from what seems to be the valve! 11 1060 Tue Apr 26, 2011 11:46 am
Leaking radiator valve 6 540 Thu Oct 30, 2008 3:31 pm
new radiator valve leaking, please help :( 6 100 Tue Aug 14, 2012 7:48 pm
Leaking radiator valve help 7 1740 Sun Aug 19, 2007 12:04 am
Leaking Cast Iron Radiator Valve 5 200 Thu Apr 28, 2011 8:23 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
