DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Help with light switch L1,L2,L3?
Author Message
satellite
from United Kingdom
PostPosted: Tue Oct 05, 2004 12:25 am Reply with quote
I have just bought a Eurolite single gang light switch and triple gang. The problem is that they have a different number system on the back from the switches I am to replace.
Eurolite switches are numbered L1 at the top and L2 & L3 at the bottom. The old triple gang has three blocks of 4 holes, with 1 & 2 at the top and the same on the bottom. How do I correspond the holes with the new switch?
Regarding earthing the brass plate - is it ok to leave the earth cable attached to the metal box at back and via short earth wire attach the brass plate to the metal box.
Back to top
 Alert Moderators
IanDB
from United Kingdom
Thanked: 2 times
PostPosted: Tue Oct 05, 2004 8:27 am Reply with quote
Yes. Insulate it with green/yellow sleeving though.
As regards the wiring, what is the configuration on the old switches? Unless you've got two way switching there should only be two connections out of the four in use on each switch.
The L2 and L3 positions are the Normally Open and Normally Closed contacts.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1970 times
PostPosted: Tue Oct 05, 2004 9:51 am Reply with quote
3 blocks of 4 holes sounds like it's a 3-gang intermediate - a very rare item.
How many wires are connected to the switch at the moment, and is it part of a 2-way, or 3-way switching system?
Back to top
 Alert Moderators
satellite
from United Kingdom
PostPosted: Tue Oct 05, 2004 2:55 pm Reply with quote
Thanks guys for your help. Yes it is a 3 gang intermeditary (I had to do further digging to find out what this is) - is it so rare? I seem to have this type of switches ( single gang, double ganges) thoughout my house, which I am gradually replacing but this triple gang foxes me.
Currently, if you can picture this:
The left gang is a two way switch with upstair's landing. It has a red wire from the wall cable attached to the top 1 and 2 holes, with separate red wires. The bottom number 1 hole has a red wire connected to number 2 hole of the middle gang - no wall cables attached.
The middle gang top number 2 hole only has a red wire attached from the wall cable. The bottom number 2 hole then is connected to the bottom number 2 hole of the third (right) gang.
The right gang also only has a red wire attached to the number 2 top hole from the wall cable. The bottom number 2 hole is also attached another red wire from the wall cable.
I hope my description is clear. How do transfer these wires to my new triple gang which only has L1, L2, L3 holes, tripled. And why are all the wires red covered.
Back to top
 Alert Moderators
satellite
from United Kingdom
PostPosted: Tue Oct 05, 2004 2:56 pm Reply with quote
PS The middle and right gangs are single switches.
Back to top
 Alert Moderators
IanDB
from United Kingdom
Thanked: 2 times
PostPosted: Tue Oct 05, 2004 3:27 pm Reply with quote
That's the live feed for the single way lights. It comes into the first switch and then is looped across to the second. On most switches the normal method of labelling is COM, L1, L2. Have a look at the "For Reference" post at the top of the electrics forum to see how your switch aligns with the layout that this shows. Once you've worked that out you can wire the live to the equivalent COM terminal on your new switch. The switched live to each light should be connected to the L1 or L2 depending which way up you mount your switch (!).
Similarly with the two way switch. The wire from the number 2 hole on the middle switch is the same live as mentioned above (if I've read your post correctly). This is linked to the number 1 hole on the two way (left hand) switch. The two red wires at the top of the switch are the feeds to the upstairs switch.
So, the top two wires will connect to the L1, L2 equivalent positions (again check for the alignment as mentioned above) with the link from the number two hole on the middle switch.
What you will end up with is a live feed to the COM position on each switch that comes in from one side and is linked across. The two way switch will have the L1 and L2 connections providing switched live to the upstairs switch and the middle and right hand switches having a single feed in L1 providing switched live to each light.
If in doubt came back and confirm any details.
Back to top
 Alert Moderators
satellite
from United Kingdom
PostPosted: Tue Oct 05, 2004 4:14 pm Reply with quote
Thanks IanDB. I think I'm understand what you're getting at. Nearly there!
When you are referring to L1 and L2, do you mean the standard L1 and L2, which includes the COM as the third hole?
Or are you referring to my L1 and L2? I think for my triple gang, L1 = COM because it is placed at the tip of the "triangle" and my L2 and L3 = L1 and L2 respectively on the standard way of numbering.
Too many L1 and L2 etc. Sorry.
Back to top
 Alert Moderators
IanDB
from United Kingdom
Thanked: 2 times
PostPosted: Wed Oct 06, 2004 7:39 am Reply with quote
Totally agree, sorry - it is getting a bit ambiguous!
Yes.
Good luck.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Light light switch 13 440 Sat Mar 21, 2009 12:32 pm
New light won't turn off at switch 9 520 Sun Mar 29, 2009 4:08 pm
Replacing Extractor Fan/How to link it to light switch 3 620 Sun Mar 15, 2009 6:01 pm
HELP! Wiring a 2 switch light with all red wiring??? 2 420 Tue Mar 03, 2009 1:26 pm
putting a switch on outside light???? 13 680 Sun Mar 01, 2009 9:48 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
