I had to drain down my system yesterday to remove a rad. When I re-filled the system the boiler would not fire up. The fan neon light was flashing - (fault guide says problem with air pressure switch).
I opened up boiler to find the band clamping the fan outet elbow to the flue had snapped. Think this was casuign the air pressure problem I put a large jubillee clip around the joint to seal it back up. Still boiler will not kick into life. There is nothing blocking flue so it must be air pressure switch I presume - anyone with any other ideas?
