Worcester 28CDi Combi Auto valve venting
20 Aug 2008
Hampshire
The heating and hot water red lights were flashing slowly and boiler wouldn't ignite to provide hot water. Previously repressurising the system cured this so attempted again. This time when the pressure of 1bar was reached, turning on the system extinguished the lights but when hot tap turned on the gas burner ignited only for approx 10 seconds, banging noises within the system, followed by steam/hot water/air venting from the air vent on top of boiler. Used pressure relief valve to release pressure in system but the above still occurred when turned on again. Any help please????
Thank you... but can you help a bit more please.
I know where the pump for the heating is situated, but didn't know the hot water system had a pump as I thought it just came out the tap under mains pressure.
Does it have a separate pump?
When I find it, how do I check it works?
