bosch dishwasher problem
9 Sep 2008
Tyne and Wear
hi
i have a bosch classix dishwasher which recently has not been emptying properly on all settings.When i have got into the socket at the back,i notice that the plug has been resting on the back of the dishwasher when it has been installed,and it has melted the plug and the back part of the dishwasher.(still switches on though).
Lastly i notice that tablets are being used now instead of salt and rinse aid.Would the latter affect the running of the dishwasher or are tablets now used to replace the salt and rinse aid ?The rinse aid and salt buttons constantly light up when i try a program.
Many thanks 4 any help given.
In relation to the last post i meant to say that i have cleaned the filter area and noticed no blockages. Cant get near pump though because it is under machine-it is still pumping water in ok though.
hi it sounds like a pump problem could be parcially blocked drain hose or bits of food in pump . is the pump louder than usuall ? take drain hose off and connect to a tap or mains water pressure let the water flush trought the wrong way it should clear any blockags but it may need to be done a few times to get rid of it all. if its a pip or glass its wont move and ull need to take off pump ..alan
I very much hope that neither of then have really melted. If the plug is damaged you must take it off and fit a new one. if the flex is damaged you must cut away the damaged part and rejoin to fresh bright copper.
Bosch dishwashers have a curious black rubbery stuff on the back to deaden sound. it is quite soft and will stick to anything it presses against. I hope this is all that has happened to yours.
You will get better results if you use salt and rinse aid and not just a multipurpose tablet
many thanks for all your help re bosch classix problem.The machine is at least working now that i have reconnected to an extension lead and socket which is well above the back of the machine and doesnt affect the plug.The machine has also worked better since i have put salt and rinse aid in.
Any advise for this next problem though.If it is set on a quick rinse,all the water drains away.if set for a longer one-eco or normal especially,the water doesnt drain away.Is this a program error possibly caused by the previous problems?
