I'm probably just about to ask the daftest aerial-related question ever posted on these forums, but it's driving me up the wall, and was hoping someone might be able to help me out
I've just moved into a new (3-storey) house in a strong reception area. There is a loft aerial with a normal co-ax plug coming from the mast. There are also three unconnected co-ax cables running down to each of the three floors. The previous owner took the connectors away with him...but I know the aerial and cables were working perfectly well before he left. My question is how do I connect them up?
To cut a long story short, I'm now just testing one of the cables (to the 1st floor...but the others have the same problem), and know I have found the right one of the three. However the picture is abysmal (both for analogue, and digital). analogue can only find one channel (CH4) which is a snowstorm, and digital can only pick up a couple of channels (music and shopping, which are the last thing I want!). I'm fully conversant with the TV/digibox/Video tuning, and as I know the set up worked previously, I reckon I'm doing something stupid at the connection from aerial to co-ax.
The co-ax cable running to the first floor has a Male (rounded) type connector (similar to that on the short cables used for running from a VCR to a TV, or TV wall plug to TV aerial socket). The loft aerial plug is similarly male, but has the exposed central wire (what I would class as the 'old-style' co-ax connector that we connected TVs with 30 years ago). I have tried connecting these with a "coax coupler" from my friendly local multi-trade outlet (£1.20 for a pack of 10...so high quality kit!), but the picture is still the same. I reckon my problem is this connection. What should I be using? I'm really confused over the type of connectors, what I've done wrong (and what the best way to connect the cables would be).
Once I've got this working, I can check that the other co-ax cables to the other floors are fine, attach my splitter, and the Mrs will be able to watch the soaps!
Can anyone help me out?
Cheers
Nick
Cheers
Nick
