DIYnot
Local | Network
   DIYnot > Forums
Local | Network
ZONE VALVE
Author Message
WSDLTD
from United Kingdom
PostPosted: Tue Sep 30, 2008 12:43 pm Reply with quote
Can any one tell me the wiring for a zone valve, i have basically a combi boiler with a 2 wire stat thats it, how do i wire in my 5 wire zone valve to that so it opens the zone valve when the thermostat calls for heat
Many thanks
Back to top
 Alert Moderators
ericmark
from United Kingdom
Thanked: 705 times
PostPosted: Tue Sep 30, 2008 1:00 pm Reply with quote
The thermostat works directly on the zone valve.
The micro switches in the zone valve work the central heating.
Eric
Back to top
 Alert Moderators
WSDLTD
from United Kingdom
PostPosted: Tue Sep 30, 2008 1:10 pm Reply with quote
so where does the power come from to control the valve and stat then?
if i wire the brown and blue direct to the stat and the grey and the orange to the stat terminals will this work then?
it shows the grey and the orange as a aux switch on the diagram
Back to top
 Alert Moderators
kablamar
from United Kingdom
PostPosted: Tue Sep 30, 2008 1:32 pm Reply with quote
The brown and blue are live and neutral that power the motor that drives the valve open. When the power is switched off (by a stat for example) an internal spring will drive the valve closed again. There is usually a lever on the side of the valve casing for manual operation.
Each valve has an aux. switch that can be used for firing the boiler, etc. The colours for this switch are normally gray and orange. It doesn't matter which way round but manufacturers diagrams will show the gray as permanent live and the orange as switched live.
Wiring diagram for two port valves here
http://www.gasman.fsbusiness.co.uk/images/spl.gif
Back to top
 Alert Moderators
kablamar
from United Kingdom
PostPosted: Tue Sep 30, 2008 1:34 pm Reply with quote
I'm asuming the fifth wire is an earth?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Tue Sep 30, 2008 3:52 pm Reply with quote
What zones are you controlling with a 3 port mid position valve on a combi?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Tue Sep 30, 2008 8:13 pm Reply with quote
This is a really poor attempt at providing information.
Please provide the make and model of the following:
. boiler
. room thermostat
. zone valve
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 301 times
PostPosted: Wed Oct 01, 2008 5:27 am Reply with quote
And what is the zone valve zoning?
Back to top
 Alert Moderators
ericmark
from United Kingdom
Thanked: 705 times
PostPosted: Wed Oct 01, 2008 9:35 am Reply with quote
This shows C system with two zone valves,
Eric
Back to top
 Alert Moderators
kablamar
from United Kingdom
PostPosted: Wed Oct 01, 2008 3:41 pm Reply with quote
Eric
A system with 2 x two port zone valves as shown in your drawing is called an S Plan. icon_wink.gif
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 301 times
PostPosted: Wed Oct 01, 2008 4:04 pm Reply with quote
And thats an overly complicated diagram too!
Back to top
 Alert Moderators
ericmark
from United Kingdom
Thanked: 705 times
PostPosted: Wed Oct 01, 2008 4:13 pm Reply with quote
You will note the pump is only used with central heating not with domestic hot water I seem to remember the S plan had both pumped but the honeywell website has been changed and I can't now find the S, C, Y and W plans any more to confirm.
Eric
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Wed Oct 01, 2008 6:10 pm Reply with quote
Is this page what you were looking for?
Back to top
 Alert Moderators
kablamar
from United Kingdom
PostPosted: Wed Oct 01, 2008 7:21 pm Reply with quote
http://www.tlc-direct.co.uk/Technical/DataSheets/Horstmann/Pics.pdf
Back to top
 Alert Moderators
ericmark
from United Kingdom
Thanked: 705 times
PostPosted: Wed Oct 01, 2008 8:02 pm Reply with quote
I agree a little over the top but it was not made to answer this post it was one I had done earlier in true Blue Peter style. Thanks for link and it seems as I thought S system pumps all the diagram was C as stated. But no one as yet has said what plan he is working on so I have no intention of designing a system when we don't have half the info.
Eric
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Fitting zone valve 4 180 Mon Feb 07, 2011 1:02 pm
Central heating zone valve replacement 7 700 Wed Apr 15, 2009 4:15 pm
Circuit for 3 way Valve 7 380 Thu Dec 11, 2008 1:32 pm
electric shock from shower valve knobs 9 3020 Mon Apr 30, 2007 2:17 pm
Gas bonding - which side of meter/valve 13 4120 Sat Oct 22, 2005 7:53 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
