DIYnot
Local | Network
   DIYnot > Forums
Local | Network
The toilet overflows, when having a shower!!!!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Dhuper
from United Kingdom
PostPosted: Sun Oct 26, 2008 12:05 pm Reply with quote
Hi, Just about 6 weeks ago when having a shower, or when downstairs in the kitchen washing the dish's the toilet starts to over flows, the toilet and shower is upstairs, the toilet is close coupled, the toilet tank has a round flat button divided in to 2 on the top, 1 for short and other for long, any help please, thank you. icon_sad.gif
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3613 times
PostPosted: Sun Oct 26, 2008 12:12 pm Reply with quote
It sounds very unlikely that washing dishes downstairs could make your upstairs toilet overflow!
Are you in Australia or on the space station??
Tony
Back to top
 Alert Moderators
Dhuper
from United Kingdom
PostPosted: Sun Oct 26, 2008 12:32 pm Reply with quote
Tony
Hi thanks for the reply, it's true when having a shower it starts to overflow, so halfway in the shower you have to flush the the toilet, I don't know if it's the plumbing I know for sure there is 2 copper pipes coming from the kitchen up to the shower room, 1 hot, 1 cold, the cold one is then is split into 4 ways shower, toilet, basin, bath, I am based in London icon_surprised.gif
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3613 times
PostPosted: Sun Oct 26, 2008 12:58 pm Reply with quote
I am beginning to think that its the toilet cistern which is overflowing and not the pan as we would at first have understood.
Tony
Back to top
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 458 times
PostPosted: Sun Oct 26, 2008 6:04 pm Reply with quote
it sounds as if the mixer valve on the shower is faulty and passing allowing water along the cold supply to the wc cistern, if there is a valve on the supply to the cistern run the shower see if it overflows then shut the valve
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3613 times
PostPosted: Sun Oct 26, 2008 6:16 pm Reply with quote
I was thinking it might be one of those dreadful float valves which needs a good mains pressure to hold it closed.
Shower use reduces mains pressure causing it to leak.
Thats only my guess though.
Tony
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1134 times
PostPosted: Sun Oct 26, 2008 6:24 pm Reply with quote
Duper, how is your hot water heated, and do you have a tank in the loft, big or small?
I'd expect as Kirk does that high pressure water is pushing low pressure water backwards somehow.
It's also possible that the cistern and some other overflow are connected together..
Back to top
 Alert Moderators
Roadyz
from United Kingdom
PostPosted: Sun Oct 26, 2008 11:50 pm Reply with quote
Tony
think agile is on the right track here, can understand this happening, but why would the shower or kitchen affect this? once the cistern is filled its filled, running other water shouldnt affect this?
look into the toilet, - is the feed to the toilet closing under normal conditions?
Back to top
 Alert Moderators
Slugbabydotcom
from United Kingdom
Thanked: 84 times
PostPosted: Mon Oct 27, 2008 12:10 am Reply with quote
I have come across this once before. I was and am still a little mystified about it but put it down to the equilibrium action of a torbeck valve in the cistern.
I took it apart, renewed the washer and put it back together and it worked fine. I seem to recall removing a little bit of debris as well. Whatever the cause it did the trick and is still working one year on.
Back to top
 Alert Moderators
muggles
from United Kingdom
Thanked: 754 times
PostPosted: Mon Oct 27, 2008 11:29 pm Reply with quote
Slugbabydotcom wrote:
torbeck valve
*shudder* unreliable blo*dy things
I'd also go for Tony's pressure drop theory, fit a fluidmaster and all will be well (they're approved for high and low pressure so any drop won't affect them)
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Wash Machine emptying water backs up and overflows 4 560 Mon Nov 27, 2006 9:30 am
header tank overflows 12 780 Mon Feb 12, 2007 9:14 am
Expantion Cistern overflows 22 5440 Tue Apr 10, 2007 1:03 pm
Combined overflows 4 280 Mon Feb 04, 2008 12:23 pm
ideal boiler C24 water overflows from external pipe 3 900 Wed Jan 17, 2007 2:37 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
