Washing Pole Fixing
27 Oct 2008
Cornwall
Folks,
I have read other postings on this site regarding not fixing tall washing poles to fence posts. I am clear that it is normally best to concrete the pole into the ground. I have a specific challenge here, that I would appreciate your help with.
My back yard is concrete. There are very secure fence posts along the side of it (100mm x 100mm), set deep into the concrete. If I was to cut into the concrete to place the washing pole into the ground, it would be a major bit of "kango-ing".
I want to secure the washing pole, via brackets of some kind, to one of the fence posts. I cant find any iron mongery that would do this. The fence post is 100mm x 100mm, there is a 20mm gap behind it that would allow a bracket to go behind. The washing pole is aluminium and 44mm across.
Any ideas?
thanks
Jim
Buy a strip of Aluminium (b+q sell it), you can bend it round your pole, cut to size, drill holes in it, then drill holes in the fence posts & secure it, 3 brkts will do
Jim - or hire a core drill to make a hole in the concrete yard, then drop the pole into the hole. Loose so you can remove the pole between washes, or fill the hole with sand/cement mortar and drive the pole into it. Once the mortar hardens the post will be 'as tight as a fish's ar*e'.
no reason why a washing line cant be fixed to a fence post that has been secur;ey concreted in. What sort of washing pole is it? why cant you just fix a plated eye to teh post if its a washing line?
Folks,
Thanks for all your answers, all good to go. Where I live is very windy, down on the north coast of Cornwall, so I was looking for a steel bracket of some kind, rather than aluminium stapping, but I will check it out in B&Q.
If that fails I will go for the core drill approach.
I need to go up above the fence pole because I want to get the washing up above the fence so it catches the wind.
Best wishes
Jim
Jim - you wrote:
"... north coast of Cornwall" & " ... I want to get the washing up above the fence so it catches the wind."
Hazard to shipping perhaps! :LOL:
The captain steps out onto the deck to admire the Cornish coastline, and gets hit in the face by a pair of pants :LOL:
