DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Help-do I need a Corgi Registered person to fit aGas cooker?
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Girlygirl123
from United Kingdom
PostPosted: Fri Nov 07, 2008 12:45 pm Reply with quote
Hello - I'm new to this site and in desperate need of some advice.
Can anyone answer me this question? My prospective father in law is fitting my new kitchen, and whilst I'm extremerly impressed with his work we are at lockerheads over whether or not it's 'allowed' for him to fit the new gas cooker. I'm positive he's more than capable of doing the job, but are there any guidelines or restrictions I need to follow? I'm worried it could jeapordise 'red tape' on the home insurance should there be a fire or an accident of some sort.
Should it be a Corgi Registered professional?
Thanks in advance.
Back to top
 Alert Moderators
mattylad
from United Kingdom
Thanked: 134 times
PostPosted: Fri Nov 07, 2008 1:22 pm Reply with quote
Does it have the quick release gas fitting?
Back to top
 Alert Moderators
Girlygirl123
from United Kingdom
PostPosted: Fri Nov 07, 2008 1:39 pm Reply with quote
God knows.... I can find out would that make a difference then?
Thx
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 50 times
PostPosted: Fri Nov 07, 2008 4:19 pm Reply with quote
girly - a quick release gas fitting will look like this:
a bayonet fitting
or like this:
a Micropoint socket
one of these (you can also get a straight bayonet - the one in the picture is an elbow) will be on the end of a gas supply pipe in the kitchen. If you have either of these you (or your nearly Father-in-Law) can attach the matching cooker hose (rubber hose with the brass fittings at the end) to this; it's a simple push & turn. You do not have to use a Corgi guy for this.
New pipework, alterations to the old pipes and rigid pipe connections to the appliance then you should use a Corgi guy. This isn't just about 'red tape' regarding the Home Insurance, it's a legal requirement to use a properly qualified person to do gas work; the Corgi organisation just happens to have a very large number of qualified people 'on it's books'.
Back to top
 Alert Moderators
mattylad
from United Kingdom
Thanked: 134 times
PostPosted: Fri Nov 07, 2008 4:20 pm Reply with quote
on the back of the cooker, thick black rubber pipe with a brass fitting on the end.
I'm sure an RGI will be along later to argue whether or not you can plug one in icon_biggrin.gif
Back to top
 Alert Moderators
Girlygirl123
from United Kingdom
PostPosted: Fri Nov 07, 2008 4:40 pm Reply with quote
How good are you guys?
I'm so impressed. Thanks ever so much. I'm a happy bunny to have the right guidance. This will definitley help the harmony within my prospective kitchen / prospective Father In Law..... icon_wink.gif
(And I've even got the hang of the smiley things).
Thanks! xxx
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 50 times
PostPosted: Fri Nov 07, 2008 10:34 pm Reply with quote
Girly - kind words are always welcome, but ...
we're dying to know what fittings, if any, you have?
Back to top
 Alert Moderators
Girlygirl123
from United Kingdom
PostPosted: Sat Nov 08, 2008 11:35 am Reply with quote
Sorry symptoms and mattylad - it's a Microsoft fitting. I mean Micropoint...yes that's it.
Back to top
 Alert Moderators
Girlygirl123
from United Kingdom
PostPosted: Sat Nov 08, 2008 11:36 am Reply with quote
Back to top
 Alert Moderators
JPC
from United Kingdom
Thanked: 20 times
PostPosted: Sat Nov 08, 2008 8:46 pm Reply with quote
it seems to me he is fitting a new cooker, so all this talk of bayonet fittings is inconsequential. it needs an rgi to install, re gas supply ok? kit units distances ok? safety chain? gas pipe position ok? Provide you with a gas work notification certificate to confirm the authenticity of the installation etc....
if no major pipework required than 50-65
Back to top
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 458 times
PostPosted: Sat Nov 08, 2008 11:58 pm Reply with quote
i am fed up hearing people say "huh how hard can it be to fit a gas cooker there is already one there" but the considerations for you (or your FIL) are: do you have test equipment, correct PTFE tape for gas, leak detector fluid, sufficient knowledge to purge and relight the existing appliances when complete? is the cooker suitable for the property (if a flat etc does it have FSD?) can you test the connections you made? is the new cooker hose OK? is the new cooker leaking? are the clearences correct? does it have a stability bracket etc etc , i would agree fitting a repacement gas cooker is easy, but i think it is easy cause i am a plumber and have been sealing and soldering pipes for 30 years, i am qualified in gas and have done CKR1 to confirm i know what i need to know about fitting cookers. AND I BET I'VE MISSED ITEMS FROM MY LIST!!!!!!!!
i have spoken to people who have fitted them and not had a problem BUT is it worth it?
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Sun Nov 09, 2008 2:00 am Reply with quote
Q:
A:
Yes!
Back to top
 Alert Moderators
Girlygirl123
from United Kingdom
PostPosted: Mon Nov 10, 2008 11:22 am Reply with quote
I'll get a Corgi registered pro. Better safe than sorry.
Thanks for the help all.
Back to top
 Alert Moderators
foxhole
from United Kingdom
Thanked: 848 times
PostPosted: Mon Nov 10, 2008 2:46 pm Reply with quote
Of course even a Corgi man can c*ck it up.The only thing guaranteed is your death.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3438 times
PostPosted: Mon Nov 10, 2008 3:07 pm Reply with quote
The simple answer is :-
If the cooker already has a hose AND there is already a suitable socket then it can be considered a DIY activity to connect them together.
However, as explained above there are other aspects to fitting a cooker!
Furthermore, although most cooker bayonet or micropoint connectors are gas tight they have been know to leak and ideally should be tested for leakage by a CORGI who will also consider all the other aspects like that safety chain etc.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
heating controls for a 90 yr old registered blind person 6 580 Mon Oct 25, 2010 6:58 pm
Heating Controls for person with Three legged Cat 2 180 Mon Oct 25, 2010 7:26 pm
Competent person? 9 620 Sun Jun 10, 2007 6:53 am
Competent person status? What is this? 9 1040 Fri Mar 12, 2004 12:25 am
plumbing pipe questions for an electrical type person 5 140 Fri Sep 23, 2011 10:58 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
