Hi
My Gas Central Heating has developed a problem whereby the boiler (NOT a combination boiler) will only ignite when the hot water is on - i.e. if I set the water tank thermostat higher, then the boiler is on more & I have a hotter house.
My CH system is pumped, and the pump is running OK.
The room thermostat seems to have no effect - if the HW is not firing the boiler, then turning up the room stat will not switch the boiler on. The room thermostat makes its usual faint click, but I guess that this message is not getting to the boiler !
Is the room thermostat the most likely failure point, or are there other things I should check ?
I'd like to be armed with an idea of the possible causes & costs before an engineer arrives.
All comments very gratefully received !
Thanks.
Thanks.
