I have a amana central a/c and heat unit about 10 years old. It has the stainless steel construction.
The unit has 2 issues. The fan was at first not running but this turned out to be the control board as I think the exlosion from the heater caused two contacts to ground out against the metal from the vibration as it sat real close to start with.
The fan will run fine now that its changed but if the explosion keeps up it will be a matter of time before it grounds out again.
The unit is in the attic. You can here the controls kicking in to ignite the gas and it sounds like the big bad wolf if trying to blow the house down, You can hear the gas blow and it sounds like it starts to ignite but is to strong so it blows itself out. Then it stops and retires the cycle over and over again until it lights and then I can hear it from my room when it fianlly gets the right fuel air mixture. Sometimes when it lights I assume because the built up gas in the chamber it will make a pretty loug explosion when it lights.
What is causing this?
I assumed maybe the small fan that is supposed to take the fumes out or possible the igniter itself but really that is all guess work.
