Hi, I have the following boiler which is three years old now. Never been serviced so I'm probably paying the price!
Recently, the boiler cuts out when the central heating has been running for about 10 mins or so. I've noticed that it seems to happen when the tank temperature reaches 60 degrees. Then it will go through self-ignition clicking and firing up etc, only to then cut out again. Once temperature drops to lower than 60 again the boiler will heat faultlessly until 60 on the dial and then will cut out again and repeat the cycle.
Hot water is not affected at all by this and the pressure is at 1.5 bar. Is it faulty thermistor, thermostat, faulty PCB, diverter etc ?
I've spent hours trying to get clues online and scoured these forums so I thought I'd raise my own post. Basically is it cheap fix or one for the engineers?
Hope you can help. Many thanks.
