Hi Everyone,
I'm looking for opinions please....
I've just had a worcester bosch greenstar 24i installed in two flats. My problem concerns winter hot water temperatures.
My installer fits these boilers as normal practice in flats of my size and maintains he gets the hot water coming out at 55C, except for my two flats where we are getting 45C.
Cold water temp is currently 7C, so we are seeing arise of 38C, which is above the 30C rise in the spec. The Worcester technical support line says they generally see a 40C rise that they see with these boilers. For reference (a) the flow rate was 9 litres per min, and (b) the specification says "domestic hot water specific rate for 30C rise 11.5 L/min."
My point (and I took this up with Worcester tech) is that every house, flat and hotel I have been in in the UK is that having a bath or shower the norm is that one has to dilute the hot with cold for a decent hot bath and shower. I think that at 45C is too low for this normal UK situation. When I mentioned this to the tech help line the operator got very defensive about the boiler and the fact it meets spec. I'm speculating here but the only reason I can imagine for a rapid change in his attitude when I started to talk about this is that they get a lot of calls about this model under-performing on hot water temperature. Certainly at some stage I would like to run a shower off the boiler and I have doubts about a nice high pressure toasty shower resulting from the current set up in winter.
I haven't done any measurements but water temperature goes up when the heating is on. Sometimes it is pleasingly piping hot, and sometimes it is just a bit hotter than the situation I describe above.
My current thought is that given that we are in the UK then UK products should accord with what I describe as the normal position above, mix hot and cold to get the right temperature (eg when I am at my girlfriend's flat, a bath is filled with about 2/3 hot water and 1/3 cold). If Worcester can't sort it out then they are selling a product that is unfit for purpose, and consumer law says that unfit for purpose products are returnable... Any thoughts about this please?
It seems to me that if the boilers are set up right (and we are getting a Worcester engineer here on Tues 23 Dec) that the one thing that we can explore is an infield upgrade to a greenstar 28i. That puts in an extra 12.5% (=1/6) and using a rough calculation, that should raise the water temperature by about 3 or 4 degrees. still not very good in my eyes.
Admittedly I am used to my old boiler where the water came out the hot tap scaldingly hot. Any thoughts here too please?
thanks
mark
thanks
mark
