heat line vizo HELP
29 Dec 2008
Cleveland
hi there
anyone out there help me please, i have a heat line vizo that has been in for about 18 months and it has started shutting down as soon as i turn the hot water tap on, it all works fine up to that point but as soon as i turn the tap it turns the flame off and starts to cool down,
any help would be appreciated as you are all aware it is hell without hot water
cheers to you all and happy xmas
steve
Probably the HW thermistor. Problem is that you have to remove the side of the combustion chamber to get at it This makes it a corgi job.
If you turn the control knob to hot water only and then turn the hot tap on, does the boiler try to fire up?
Slugbabydotcom, it is possible to remove the dhw thermistor without removing the chamber cover, using a 13mm spanner (ratchet type works great). If it were the sensor than the light on the facia flashes on this model, and surprisingly I've been to a faulty dhw sensor and the boiler still fired up for hot water demand (didn't get very hot mind you).
yes i thought of that but the problem is that the heating system works fine and i thought that if it was the chamber stat it would effect the heating as well, sorry to sound negative but just need to try and get it working again,
also does anyone know where i can get a manual or fault finding sheet from,
cheers again
steve
zk
cheers for that and if it is in hot water only then yes it does fire up and i have noticed that the temp lights go up to four lights and then it shuts down, cools a little then flashes up again then shuts down ect ect i think you get my drift lol.
any advice on what i can do would be greatly appreciated, i have been told there is a temp sensor somewhere so any pointers there as well please. not sure if i can short it out to give me temp hot water
cheers
steve
As if the world was as easy as that!
Get a "fault finding sheet" and you are set up as a boiler expert!
Tony
It does sound as the plate heat exchanger is blocked. If the heating is not getting hot, than I'd be inclined to check the fillter in the return isolator on the central heating pipework. (hope it is fitted on the return and not the flow)
Sorry didn't notice that the heating was working ok :oops: Still it wouldn't be a bad idea to check the filter when draining down the boiler.
