DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fiat headlight problem
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
micktheframer
from United Kingdom
PostPosted: Tue Jan 20, 2009 9:10 pm Reply with quote
I have a Fiat Punto 60S R Reg, 1997. Whenever I try to turn the headlights on, only sidelights come on both sides, although the switch on the steering column stalk is turned to the headlight setting. I have taken the car to a fiat dealer, who think that it is unlikely there is a problem with the bulbs. They did however say that it could be either a bad connection to the lights, or a fault within the column stalk. I personally don't think that the stalk is faulty as beforehand, one headlight worked as normal, while the other did not, suggesting that the stalk was still working. Any help or suggestions would greatly appreciated.
Back to top
 Alert Moderators
ch427
from United Kingdom
Thanked: 166 times
PostPosted: Tue Jan 20, 2009 9:20 pm Reply with quote
dont think much of their diagnosis!
you need to start off with testing at the lamp connectors to see if you have 12 volts there,could be anything from faulty fuses to a duff relay
Back to top
 Alert Moderators
cjard
from United Kingdom
Thanked: 2 times
PostPosted: Wed Jan 21, 2009 1:02 am Reply with quote
i'd start by testing the bulbs, and then work back down the wiring system from there.
Back to top
 Alert Moderators
micktheframer
from United Kingdom
PostPosted: Wed Jan 21, 2009 6:59 pm Reply with quote
Hi to those who replied, many thanks for your help, a good starting point.
Once again, thanks
Mick
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
c5 headlight/indicator problem 4 60 Tue Oct 11, 2011 3:23 pm
Nissan Micra headlight problem 4 80 Wed Feb 08, 2012 6:40 pm
1992 Renault Clio Headlight Problem 3 760 Tue Nov 21, 2006 5:58 pm
Headlight problem??? 6 980 Wed Nov 01, 2006 6:02 pm
Replacing headlight units on a VW Polo ,advise please 3 380 Sun Oct 24, 2010 7:37 pm
DIYnot
