DIYnot
Local | Network
   DIYnot > Forums
Local | Network
vauxhall Astra
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
rockdg
from United Kingdom
PostPosted: Sun Feb 15, 2009 2:35 pm Reply with quote
Hi
The boot on my vauxhall astra will not open. When using the electronic key to open all the doors, each one, front and back operate but the boot will still not open when you lift the handle. Can anyone help before i have to put the car into a garage. I can't find a release handle if it actually exists.
Back to top
 Alert Moderators
gregers
from United Kingdom
Thanked: 424 times
PostPosted: Sun Feb 15, 2009 6:16 pm Reply with quote
try using the key,on some cars if you turn the lock on the rear hatch it stops the hatch from opening using the remote fob.
Back to top
 Alert Moderators
andy1020
from United Kingdom
Thanked: 3 times
PostPosted: Sun Feb 15, 2009 7:35 pm Reply with quote
hi,
i'd crawl into my boot and take the panel off the inside of the boot and that should let you in at the lock mechanism from the inside to flip the lock open yourself. I've done this on lots of cars, can't guarntee will be ok for your astra..
Back to top
 Alert Moderators
m4lcy129051
from United Kingdom
Thanked: 1 time
PostPosted: Mon Feb 16, 2009 7:59 pm Reply with quote
[hi rock on your lock wich way is the slot for the key facing it should be acrose for central locking to open
Back to top
 Alert Moderators
KingboyD
from United Kingdom
Thanked: 43 times
PostPosted: Mon Feb 16, 2009 8:05 pm Reply with quote
Astra H?? Post 2004?? If so then tilt rear seats forward and gain access to boot, in the center of the boot pannle there is a round gromit, remove this gromit and with a large flat head screw driver insert into the hole icon_eek.gif and turn icon_razz.gif boot should pop open!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Vauxhall Astra Rear Windscreen Washer Jet 2 80 Sun Mar 01, 2015 9:36 pm
Vauxhall Astra engine symbol light 2 1420 Sun Mar 22, 2009 7:16 pm
Vauxhall Astra MK5 H Diesel losing Power 8 4800 Fri Jan 15, 2010 5:38 pm
Replacing brake disc, Vauxhall Astra. 3 160 Fri Oct 11, 2013 8:00 pm
need help vauxhall astra 1.4 16v 2000 5 120 Thu May 02, 2013 6:22 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
