jack5751
Joined: 07 Mar 2009 Posts: 2 Location: United Kingdom
Posted: Sat Mar 07, 2009 2:38 pm |
Hi i have a Vokera, mynute 20e. a while ago pump was leaking. turned off water and left system off. 3 months later back in house switched on boiler all ok. 1 month later pressure dropping to 0psi after 2 days. have just looked at pump and it is hard to turn and very hot i beleive it may be seized. also no hot water coming through taps do u think the pump faulty and do i also have another problem, could not find leak from pump 2nd time round. |
ChrisR
Joined: 24 Jul 2003 Posts: 23083 Location: London, United Kingdom Thanked: 936 times
Posted: Sat Mar 07, 2009 3:09 pm |
If you're saying you've taken the centre screw out and the shaft doesn't turn, yes it's faulty. Presumably the boiler won't run at all?
If it has a go at running and boils because the pump isn't going (which I don'y trhink it shjould, but ...) then it might well squirt water out of the pressure relief valve. See FAQ for insight on that - Boiler Pressure Problems. |
jack5751
Posted: Sun Mar 08, 2009 3:39 pm |
thanks 4 reply |
