DIYnot
Local | Network
   DIYnot > Forums
Local | Network
New lawn - grass seed or turf?
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
Author Message
will_uk
from United Kingdom
PostPosted: Sat Mar 07, 2009 3:57 pm Reply with quote
If you were re-turfing/seeding a smallish lawn (50m2 - ish), what's the best way to go about things?
Basically, the lawn where I am is all over the shop at the moment - parts of it are dead where they were left covered by stuff for ages, a pile of soil has been moved from where a shed base was dug up etc. Good soil though and everything grows ok it seems.
I'm hoping to level it all out a bit and then returf it. What's better, quality turf or seed? Any recommended suppliers?
Do I need to remove as much of the old grass or can I just dig it all over/rake it out/wack it down a bit if using turf? I've got a wacker plate which I can use to flatten everything down with a bit if needed (before finally raking over etc).
Any pointers/advice much appreciated
Will
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat Mar 07, 2009 4:10 pm Reply with quote
as i understand it, turf is for instant grass, seeds are to grow your own. seeds being cheaper.
whaker plate.......................never seen one of those used for a lawn on GF (i think it would compact too much) but like painting the end result really depends on the prep you do, the more and better it is the better the end result
Back to top
 Alert Moderators
r896neo
from United Kingdom
Thanked: 538 times
PostPosted: Sat Mar 07, 2009 5:43 pm Reply with quote
seeding it is a probably less work and definately cheaper. Kill everything with a couple of applications of roundup or similar then dig it all over with a rotovater or fork if you don't mind the work throw a bit of fertilizer on it ( if the soil is heavy or poor add some sand and or topsoil now) and rake it all to a fine crumb. Then level it out and roll it with a heavy roller, i wouldn't use a whacker plate. Then seed away.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
Lay turf or carry on with grass seed? 5 700 Wed May 21, 2008 12:44 pm
grass , turf or seed 2 200 Sat Dec 18, 2010 9:22 pm
Levelling soil in prep for lawn seed or turf 3 200 Mon Mar 10, 2014 10:57 am
Turf or Lawn Seed 12 180 Mon Feb 27, 2012 10:42 am
Weed and Feed Lawn and then add grass seed ? 2 4900 Sun Mar 09, 2008 4:15 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
