I am installing an integral pullcord-operated bathroom extractor with no timer overrun. The fan is powered from the mains lighting circuit via a triple-pole isolating switch.
I want the fan to work independently of the light. Therefore, I have taken the permanent live and neutral from the light into the supply terminals of the isolating switch using T/E cable, then connected live and neutral from the output terminal of the switch to the fan itself (which is double insulated so no earth).
The problem is that the fan operates perfectly when the light is OFF but does not operate at all when the light is ON. Can anyone explain to me what I have done wrong ?
