DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Damp proofing a cellar
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
mat59
from United Kingdom
PostPosted: Wed Apr 15, 2009 7:40 pm Reply with quote
Hi everyone. I've been reseraching how to damp proof my cellar to use it for storage.
I am looking for some advice on how to do this. I'm looking to do it cheaply and as the cellar is not very damp I was hoping to apply a damp proof paint rather than using a plastic membranne and sump.
The cellar is damp but not excessively. My next door neighbour has successfully damp proofed his cellar (used as a hobby room) using Johnstones damp proof paint http://www.decoratingwarehouse.co.uk/catalogue.php?productid=104
I was thinking of using a black bitumen paint -http://www.wickes.co.uk/Liquid-Damp-Proofing/Liquid-Damp-Proof-Membrane/invt/241217 - and eventually painting over this with a white paint.
I've tried using some of the bitumen paint on the walls with poor results. I've brushed the walls down but the paint does not adhere to the pointing between the bricks as it is still dusty and crumbly.
A local builder advised me that I should use PVA paint as this will stop the surface from crumbling. I presume I could use PVA and then bitumen paint over the top?
Any advice on what to do would be much apprecited.
Thanks,
Matt
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1460 times
PostPosted: Wed Apr 15, 2009 8:18 pm Reply with quote
If your neighbours been successful using the Johnstones stuff why not just use that?
Back to top
 Alert Moderators
mat59
from United Kingdom
PostPosted: Wed Apr 15, 2009 9:23 pm Reply with quote
Hi. The Johnstones stuff is expensive. The bitumen stuff should do the job, it's just difficult getting it to adhere to the wall. Can i use PVA to create a firmer surface to adhere the bitumen?
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1460 times
PostPosted: Wed Apr 15, 2009 10:58 pm Reply with quote
If you can damp proof a cellar for 45 its cheap at 100X the price!
Back to top
 Alert Moderators
wavetrain
from United Kingdom
Thanked: 20 times
PostPosted: Thu Apr 16, 2009 12:19 pm Reply with quote
Most BCOs would be of the opinion that it is impossible to damproof a cellar with paint alone since a simple film of paint needs to hold back the hydrostatic pressure of water in the soil behind.
And anyway the datasheet on your paint specifically excludes your situation since you have a defect which is making the brickwork damp.
There are innerwall drainage systems for cellar which either vent the moisture away or pump it away at intervals, I suggest you google them.
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1460 times
PostPosted: Thu Apr 16, 2009 12:37 pm Reply with quote
Back to top
 Alert Moderators
wavetrain
from United Kingdom
Thanked: 20 times
PostPosted: Thu Apr 16, 2009 2:20 pm Reply with quote
This got me thinking how semi-basement flats are built, you know the type in London where you look down on the basement flat as you walk past, but the next sory up is a quite a few steps up.
I am guessing they could be made by a concrete slab for floor in the basement then the floor and walls tanked with bitumen then inner walls and further concrete slab put over the tanking.
I have allways fancied a basement, I may start digging one this weekend as long as I can find a hole to put the clay I will need to dig out.
Back to top
 Alert Moderators
alittlerespect
from United Kingdom
Thanked: 47 times
PostPosted: Sun Apr 19, 2009 9:35 pm Reply with quote
Your best bet would be to invest in a material called 'synthaproof', apply 3 coats. To find out more about synthaproof do a www. search. First coat will be a bit hit and miss, but dont worry, second coat will get 95% of the bits you missed the first time and the third coat should give a hit of around 99.9%
You will need to work out your wall area to determine the amount of material you will need.
Regards
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Damp proofing cellar without drainage 4 80 Mon Nov 28, 2011 9:35 pm
Suggestions for Cellar Floor (damp proofing) 13 260 Sun Sep 07, 2014 11:26 am
Damp Proofing Non-Damp Cellar 3 60 Tue Sep 24, 2013 12:08 pm
Basement tanking/ cellar damp proofing 3 120 Sat May 21, 2011 11:30 am
Damp Proofing my Cellar 6 120 Tue Feb 19, 2013 7:44 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
