DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hot water very slow out of bath tap
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
IronNaz
from United Kingdom
Thanked: 12 times
PostPosted: Fri Apr 17, 2009 8:18 am Reply with quote
Hi, was wondering if someone could advise on this problem.
I went out to a house yesterday where the customer was saying the water from the hot water tap on the bath was coming out very slow. I tried it and it was a very low discharge rate. The cold water tap was fine. I checked the hot water tap on the basin which was nearby, but that was working fine, as was the hot water from the kitchen sink.
I assumed therefore that it must be the bath tap thats faulty, so changed the bath tap to a new one (which I always keep with me). However again same problem. I took apart the old tap and it seemed fine, no faults, it was relatively new. Customer says he had this changed about 6 months ago to address the issue of the low rate of water, but had done little to improve it.
So i'm at a loss as to whats causing the issue. Does anyone have any ideas on what it could be?
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Apr 17, 2009 9:22 am Reply with quote
whats the taps fed from gravity cylinder ?
what size are the feeds ?
have you tried flushing the pipe through with mains pressure ?
Back to top
 Alert Moderators
IronNaz
from United Kingdom
Thanked: 12 times
PostPosted: Fri Apr 17, 2009 9:38 am Reply with quote
Its direct fed, combi system.
I've not tried flushing through at mains pressure, to be honest wouldnt know how to do this on the hot water pipe. I've only recently started on this plumbing work and this is one of my very first callouts.
I'm assuming based on what you have said that the fault is probably a blockage in the pipe?
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Apr 17, 2009 9:47 am Reply with quote
if its from a combi then it will be mains pressure.
i take it the basin hot comes off the same pipe as the bath hot, so the block can only be between the basin/bath.
can you see any isolation valves in the hot pipework to the bath ?
Back to top
 Alert Moderators
IronNaz
from United Kingdom
Thanked: 12 times
PostPosted: Fri Apr 17, 2009 10:33 am Reply with quote
There was an isolation valve on the pipework between bath and sink.
Thanks for your advice, really do appreciate it.
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Apr 17, 2009 10:54 am Reply with quote
check that something maybe lodged up against it.
Back to top
 Alert Moderators
david17uk
from United Kingdom
PostPosted: Fri Apr 17, 2009 3:08 pm Reply with quote
Back to top
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 458 times
PostPosted: Fri Apr 17, 2009 9:11 pm Reply with quote
if there is a cylinder fitted it may be a tiny bit of foam lagging which got into the tank when it was fitted, i know a guy who fitted a cylinder for his friend ( icon_redface.gif icon_redface.gif ) then a couple of years later had a prob with basin tap as described in this post, when he ( icon_redface.gif ) turned water off couldnt see anything but as no pressure on pipe foam fell back into pipe and couldnt be seen, eventually had to take basin supply pipe out and found foam lagging bent and shaped to size of pipe and restricting flow, so it can happen after a fair length of time
Back to top
 Alert Moderators
david17uk
from United Kingdom
PostPosted: Fri Apr 17, 2009 10:01 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
hot water slow from bath tap only 10 1420 Mon Jun 11, 2012 9:57 am
Bath Waste water - slow flow 3 420 Tue Apr 22, 2008 1:35 pm
Brand New mixer bath tap. Very slow hot water. 6 160 Thu Jan 20, 2011 10:00 am
Slow hot water from bath tap 14 800 Sat Nov 22, 2008 9:56 pm
Hot water is slow out of all taps excpet the bath. 6 820 Fri May 30, 2008 11:45 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
