| Author |
Message |
andy963
Joined: 20 Apr 2009 Posts: 3 Location: London, United Kingdom
Posted: Mon Apr 20, 2009 9:28 am |
HI new to this forum
I would just like to know would be it okay to add a spur but take the feed directly from the ring main circuit breaker to the spur,instead of tapping into the ring at all.
Its just easier to fit twin socket run cable directly to c/u
thanks |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
holmslaw
Joined: 12 Dec 2006 Posts: 5844 Location: Vanuatu Thanked: 400 times
Posted: Mon Apr 20, 2009 9:32 am |
| Back to top |
rebuke
Joined: 04 Nov 2008 Posts: 871 Location: Cambridgeshire, United Kingdom Thanked: 25 times
Posted: Mon Apr 20, 2009 9:41 am |
I believe there's a regulation (not 100% sure though) that says you should only have as many spurs as you have accessories on the ring, so if every existing socket/FCU on the ring already has a spur from it, then you can't, but otherwise it should be OK.
You could always extend the ring by using crimps to connect one leg to a new cable, run that to your socket, then another cable back to the breaker... |
| Back to top |
andy963
Posted: Mon Apr 20, 2009 10:36 am |
Thank you chaps for the speedy response one more thing would i have to complete a cert just for that installation on that circuit only
cheers. |
| Back to top |
rebuke
Posted: Mon Apr 20, 2009 11:09 am |
Well, under BS7671 (the wiring regs) you should complete a minor works certificate (MWC), listing the test results etc. If you don't have any test kit though, then obviously that's a bit hard to do. BS7671 however is not a legal requirement...
Assuming the extra socket is not in one of the specific areas mentioned in Part P (bathroom, kitchen, outdoors etc), then the work is not notifiable to building control, so you don't need to get a completion certificate for it etc. |
| Back to top |
andy963
Posted: Mon Apr 20, 2009 11:19 am |
| rebuke wrote: | Well, under BS7671 (the wiring regs) you should complete a minor works certificate (MWC), listing the test results etc. If you don't have any test kit though, then obviously that's a bit hard to do. BS7671 however is not a legal requirement...
Thats great cheers buddy... Do have megger etc just a newbie to the game wasnt to sure weather to test individual circuit, or full test on all the circuits etc.. |
| Back to top |
ColJack
Joined: 16 Feb 2007 Posts: 11772 Location: West Midlands, United Kingdom Thanked: 408 times
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
