DIYnot
Local | Network
   DIYnot > Forums
Local | Network
best position for room stat
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
fingertight
from United Kingdom
Thanked: 8 times
PostPosted: Thu Apr 23, 2009 7:25 am Reply with quote
Hi Guys,
ive recently started central heating install with a new partner..up until this point, as long as i had 1 meter clearance from the bypass rad, I always located the stat in the downstairs hall, for conveinient use by the client and i think it more likely to give a more comfortable temp reading (heat rises etc) HOWEVER icon_eek.gif my partner insists it is put on the landings upstairs....Which one is right? My view that if the stat is upstairs and it is set to 20c, then it will shut system off at that temp, but downstairs wont be at 20c cause heat rises..so you constantly fall short downstairs..where most of peoples time is spent..and you have to run upstairs to reset stat. I know if the stat is downstairs and set to 20c, then when target temp is achieved downstairs, it will be 20c downstairs, although upstairs will be slightly warmer. Again..which is right? thanks in advance.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 771 times
PostPosted: Thu Apr 23, 2009 8:25 am Reply with quote
The hallway has always been the traditional position for a room stat.
Many today will fit it in the lounge.
Personally I wouldn't fit it on the landing, but it should still work.
Back to top
 Alert Moderators
BingoBongo
from United Kingdom
Thanked: 92 times
PostPosted: Thu Apr 23, 2009 10:55 am Reply with quote
fit an rf then you can take it anywhere you like and lose it under the bed like me icon_biggrin.gif
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1435 times
PostPosted: Thu Apr 23, 2009 10:59 am Reply with quote
put it in a living room, where the comfortable temp is most important.
the hall will get cold every time the front door is opened
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 771 times
PostPosted: Thu Apr 23, 2009 11:08 am Reply with quote
And the living room too warm if they have a fire on as well, as a lot of people do for some reason.
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 421 times
PostPosted: Thu Apr 23, 2009 6:25 pm Reply with quote
Hall is my prefered option.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Where to position room stat? 5 620 Sat Sep 10, 2005 9:23 am
Where to position digital room stat 12 240 Wed Dec 04, 2013 4:03 pm
New waste pipe position for sink in downstairs toilet room 2 600 Fri Feb 10, 2006 8:56 pm
ideal position and temp setting of room thermostat 2 640 Wed Jan 04, 2006 6:25 pm
position of room thermostat 2 60 Sun Jul 24, 2011 10:48 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
