Hi All,
Last night I had to deal with an unfortunate accident. I had just come out of the shower and switched it off (at the shower and not the mains). I have a triton electric shower. I then turned the shower (at the shower) on to clean the bath but the high setting would not work so I used the medium setting to clean the bath, I switched the shower off having cleaned the bath and pressed the high button to see why it won't work. It didn't turn on the shower. So I left it and went downstairs (I forgot to switch off at the mains). After 20-30 mins, I noticed that water was dripping from the ceiling of the dining room (the room below the bathroom). I dashed upstairs to see the bathroom flooded with water with the shower running. Unfortunately the shower head was pointing in the direction of the middle of the bathroom rather than the bath (which would have been OK as the water would have gone through the bath)
The floor area (storage area) beneath the bath had a lot of water which then went through the floorboards and through the ceiling in the dining room and on floor as well.
I apologise for the long winded description of the cause (I thought it would help understand my predicament).
The ceiling has stained considerably and also part of it looks as though it is lower than the rest (not that obvious though). I'm not sure if the ceiling is plain plaster or a combination of plaster and plasterboard.
What I would like to know is how long would this take to dry in both cases? (this is my most important question), Is there anything I can do to speed things up in terms of drying in both situations? Is there a potential to for it collapse or have problems later on? Any advice on whether I should have it repaired by replastering it after it has dried? I'm not sure that it's quite an insurance claim but the ceiling looks awful and is still damp.
I have quite a terrible 24 hours so any help and advice will be gratefully appreciated.
