Repressurising central heating system
18 Dec 2004
Can you tell me how to repressurise a Worcester Bosch central heating system
If the cH system has pressure gauge then it will probably have a filling loop too.
find the filling loop. it is a connection from the cold water mains pipe to the central heating pipes. It is usually a silver, flexible pipe with an on off valve at one end, it is usually under the boiler.
have a look at the boiler manual if you have it. If not then if I were you I would try and download it or write to the manufacturer for a new one.
