Tricity Bendix AW1000
22 Dec 2004
HI,
Can some one help please?
My washing machine half way through the wash cycle tries to spin, stops and tries to spin again. If I switch it off for roughly 15 minutes and start it again where I stopped it it washes fine for a while but then goes through the same routine again. If I empty all the water out and try to spin, it will do the first and second speed ok but will not get up to the 1000 rpm spin speed. I have renewed the brushes on the motor. Any help would be appreciated. Thanks. :evil:
pehaps it doesnt want to.
it may be the out of balance sensor stopping it, try it with m/c empty see what happens
Thanks for that, I'll give it a try tonight. Where will I find this out of balance switch. :eek:
its not a switch its an inductance coil, but if broken they usually ONLY spin
Hi Breezer,
I tried what you suggested, but to no avail. I watched the machine from the start of the cycle (normal 40c wash with nothing but water in the machine) but 20 minutes in, it tried to spin in the wash mode. My next action was to start the cycle again from the beginning, and straight away it tried to spin. So, then I put it to the spin position on the controller, it emptied out the water, done the little fast spirt, and stopped. This happened two or three times, I then stopped the machine for 15 minutes and tried the spin again. This time it spun properly going up in gently in speed to its full spin speed.
My machine doesn't appear to have an "Unbalance Sensor". All the cables going to the controller are accounted for. Any suggestions????? :evil:
