What (bleedin) size do you need to connect to!? You can get fittings to go from 8, 10, 12 to 15 from anywhere or 14, 16 or 18mm and all the imperial sizes, from a good merchant.
They might not work properly after they have been fitted as a lot of continental taps are designed to work on high pressure and run very slowly on the standard british tank fed supply
