Hi
I have a Worcester Heatslave oil boiler 20/25 and the boiler is sometimes noisy. Runs fine but I would like to solve the noise and ensure when I am working away the family don't get stranded.
Initially I suspected the water pump because the problem started when I forgot to turn the boiler off during a drain down (bad mistake) so it started and kettled what water was left. I therefore thought I may have cooked the pump bearings and they are now the culpritt.
Having just started the boiler up typically the water pump is silent and the boiler is running pretty quietly - typical! If I use a screwdriver on the fan housing I can hear a pulsing drone. If I listen at the flue the burner is running smoothly.
I am therefore thinking I might have early signs of the bearings going in the fan motor. I saw replacment of these described elsewhere on the forum - //www.diynot.com/forums/viewtopic.php?t=66290
Does it sound like I need to pull the fan out?
Any tips greatfully received.
Regards
Jeremy
Regards
Jeremy
