DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Honeywell CM67 Wireless Thermostat behaving odd
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
ssjjsd
from United Kingdom
PostPosted: Sun Nov 01, 2009 10:56 am Reply with quote
Please help, my Honeywell CM67 Wireless Thermostat which has worked for about 5 years without any problems has recently started to turn the boiler on outside of the programmed on/off times, if I switch to AUTO, the boiler fires up even though the off time is 9:30 am and the next on time is 6:00pm??? icon_rolleyes.gif
Back to top
 Alert Moderators
Tris123
from United Kingdom
Thanked: 1 time
PostPosted: Sun Nov 01, 2009 12:32 pm Reply with quote
May sound stupid but have the batteries been changed recently? if they have check the receiver box on a combi should be near the boiler if a heat only probably in the airing cupboard a red light usually indicates a problem with signal and will probably need a rebind.
Also, check when you put it on auto if the green light comes on on the receiver if so check your off temps on your thermostat.
Back to top
The following user says thank you to Tris123 for this useful post:
ssjjsd (2 Nov 2009)
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sun Nov 01, 2009 1:23 pm Reply with quote
Override by any chance?
Back to top
 Alert Moderators
dreadnoughtheating
from United Kingdom
Thanked: 309 times
PostPosted: Sun Nov 01, 2009 7:42 pm Reply with quote
Has the optimisation option be reactivated? I can supply instructions on how to 'de-activate' if needed.
DH
Back to top
 Alert Moderators
ssjjsd
from United Kingdom
PostPosted: Mon Nov 02, 2009 12:21 am Reply with quote
Cheers but a re-bind seems to have solved the problem
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Central heating behaving oddly 11 600 Wed Dec 31, 2008 2:41 pm
Central Heating Behaving strangely 15 700 Tue Nov 25, 2008 7:48 pm
Ferroli Boiler ...not behaving! 2 220 Fri Oct 16, 2009 7:43 am
Halstead ace - not behaving! 2 160 Sun Nov 15, 2009 9:39 am
Baxi Combi 105e behaving oddly..... 7 300 Wed Oct 20, 2010 7:08 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
