DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ford Focus 1.6 Engine Management Warning Light
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Sun Dec 13, 2009 12:47 pm Reply with quote
Engine (amber light) staying on.
I have read the code & its '969E' anyone got any ideas.
Back to top
 Alert Moderators
^neo^
from United Kingdom
Thanked: 43 times
PostPosted: Sun Dec 13, 2009 1:04 pm Reply with quote
what did you read the code with?
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Sun Dec 13, 2009 3:11 pm Reply with quote
Turn ignition on holding the trip reset button. It then displays test. Dials speedo, rev counter temp gauge & fuel gauge all move, then the code comes up. Found that on the web, now I want to know what the code is telling me & how to reset.
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 157 times
PostPosted: Sun Dec 13, 2009 4:03 pm Reply with quote
Back to top
 Alert Moderators
^neo^
from United Kingdom
Thanked: 43 times
PostPosted: Sun Dec 13, 2009 4:05 pm Reply with quote
Ok.
What you have done is not the most reliable of scans. If you're worried about it then get an OBDII scanner on it.
From a quick google search the '96**' block seems to be the Ford PATS immobiliser system.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Sun Dec 13, 2009 4:38 pm Reply with quote
Stivino wrote:
http://www.obd-codes.com/trouble_codes/ford/
http://www.autodiagnos.com/fileadmin/assets/en/downloads/pdf/technical_bulletins/ford/ford_dtc.pdf
I had found these sites & spent a bit of time looking, my error code starts '9'
these are all 'P'.
It could be p & 9 are similar as its on the display.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Sun Dec 13, 2009 4:40 pm Reply with quote
^neo^ wrote:
Ok.
Neo, does this mean I have to take it a garage that has the OBD11 Scanner?
What does the Ford PATS immobilser system, mean
Thanks for taking the time.
Back to top
 Alert Moderators
^neo^
from United Kingdom
Thanked: 43 times
PostPosted: Sun Dec 13, 2009 4:53 pm Reply with quote
yep, get a proper scan done on it and see whats there.
Pretty much every garage in the country should have a scanner to get the codes, so doesnt have to be the dealer / specialist or the likes.
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 157 times
PostPosted: Sun Dec 13, 2009 5:06 pm Reply with quote
these are all 'P'.
I posted the links as a nice way to let you know that your scan result was meaningless, I didn't realise you'd been there already.
Back to top
 Alert Moderators
gregers
from United Kingdom
Thanked: 424 times
PostPosted: Sun Dec 13, 2009 6:01 pm Reply with quote
join here
www.ffoc.co.uk
ask there wether there is anyone near to you who has a scanner and scan your car for some beer tokens?
or ask there for the correct lead for your car,bet it will cost less then half what ford will charge you for a scan,
iirc they will charge iro 85 or whatever they charge per hour.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Tue Dec 15, 2009 8:40 am Reply with quote
gregers wrote:
join here
www.ffoc.co.uk
I joined...Oh what a strange forum, you have to pay to look at certain things.
I would call it a privaye club.
Was advisd to post in the general chat area, got advice, disconnect the battery re connect & see if it re appears.
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2564 times
PostPosted: Tue Dec 15, 2009 9:00 am Reply with quote
I use a Gendan GCR10 code reader...does engine light diagnostics and resets, for less than 100. It scans any petrol car 2001 or newer and any diesel car 2004 or newer. Tremendous bit of kit.
Back to top
 Alert Moderators
gregers
from United Kingdom
Thanked: 424 times
PostPosted: Tue Dec 15, 2009 7:55 pm Reply with quote
Diyisfun wrote:
gregers wrote:
join here
www.ffoc.co.uk
soz m8 must have change there policy,think its to stop the technical info being used and abused?
look on ebay for scanners,i was in gsf at the weekend and iirc they had a hand held scanner for less then 50.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Wed Dec 16, 2009 3:04 pm Reply with quote
Not going to buy a scanner if I cant do the fix.
Will see what happens after I disconnect the battery.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Fri Dec 18, 2009 8:17 am Reply with quote
Got a free scan, it was fuel gauge or fuel sensor, they think because I filled the tank. I always do hate going to petrol garages.
Anyway he has reset it.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
ford focus engine management light on 2 240 Sat Jul 20, 2013 11:14 pm
engine management light 3 1700 Tue Jun 08, 2004 9:28 pm
Volvo V70 engine management light 3 1580 Sun Aug 08, 2004 8:05 pm
citroen Berlingo multispace engine management light 10 13180 Fri Feb 18, 2011 8:07 pm
Engine management light on 1998 corsa 1.0 12v 4 1100 Thu Jun 17, 2010 10:12 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
