DIYnot
Local | Network
   DIYnot > Forums
Local | Network
lower tyre presure in snow
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > General Cars
Author Message
arcticoceans
from United Kingdom
PostPosted: Mon Jan 04, 2010 4:40 pm Reply with quote
if i lowered the presure in my tyres will they give me better traction in the snow and ice were all having lately. good or bad idea.
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2602 times
PostPosted: Mon Jan 04, 2010 5:06 pm Reply with quote
Not recommended - some people swear by it but only reduce by a couple of psi if you want to.
Back to top
The following user says thank you to Burnerman for this useful post:
arcticoceans (4 Jan 2010)
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 467 times
PostPosted: Mon Jan 04, 2010 5:12 pm Reply with quote
approx 4-5 psi lower than recommended will increase footprint of tyre and will help but don't exceed 20% of normal pressure that is what i was told by our tyre fiiter.
Back to top
The following user says thank you to kevindgas for this useful post:
 Alert Moderators
Stivino
from United Kingdom
Thanked: 159 times
PostPosted: Mon Jan 04, 2010 6:45 pm Reply with quote
Back to top
The following user says thank you to Stivino for this useful post:
 Alert Moderators
Peter.N.
from United Kingdom
Thanked: 221 times
PostPosted: Mon Jan 04, 2010 7:28 pm Reply with quote
Certainly not recommended if you are going to drive fast on them but purely for driving on soft snow it will improve traction, but pump them up before setting out on the open road again.
Back to top
The following user says thank you to Peter.N. for this useful post:
 Alert Moderators
Stivino
from United Kingdom
Thanked: 159 times
PostPosted: Mon Jan 04, 2010 8:14 pm Reply with quote
Peter.N. wrote:
Certainly not recommended if you are going to drive fast on them but purely for driving on soft snow it will improve traction.
From The AA website.
"Don't reduce tyre pressures to get more grip – it doesn't work, and reduces stability".
From Michelin websire.
"Our advice:
When setting your pressures with cold tyres (tyre temperature at the outside ambient temperature), set them to the vehicle manufacturers’ recommended pressures".
Back to top
 Alert Moderators
arcticoceans
from United Kingdom
PostPosted: Mon Jan 04, 2010 9:21 pm Reply with quote
i think i will keep my tyre presures as recommended,
Back to top
 Alert Moderators
Peter.N.
from United Kingdom
Thanked: 221 times
PostPosted: Mon Jan 04, 2010 9:51 pm Reply with quote
Thinking about it, my experience of increased grip at low pressure was with cross ply tyres, maybe its not as effective with radials.
Back to top
arcticoceans (5 Jan 2010)
 Alert Moderators
wotan
from United Kingdom
Thanked: 141 times
PostPosted: Tue Jan 05, 2010 1:57 am Reply with quote
Smooth acceleration, and breaking, possibly starting off in second gear, is what I understood to be the correct way to drive in snowy conditions, anticipation is vital to staying safe.
Wotan
Back to top
The following user says thank you to wotan for this useful post:
 Alert Moderators
arcticoceans
from United Kingdom
PostPosted: Tue Jan 05, 2010 7:17 am Reply with quote
just thought i was missing out on something the way other drivers speed in the snow.
must have afew idiots around these days, 30 years at the wheel just cant believe what i see others do,
nether mind atleast my car will stay straight "i hope"
Back to top
 Alert Moderators
empip
from United States Minor Outlying Islands
Thanked: 50 times
PostPosted: Tue Jan 05, 2010 1:59 pm Reply with quote
http://www.rallybuzz.com/snow-tyres-dropped-wrc/
Quote:
...Pirelli will replace the traditional skinny snow tyres with a version the same size as those used on gravel for Rally Norway 2009, according to Autosport magazine....
...Pirelli rally manager Mario Isola explained to Autosport:
[I]"We've tested the new tyre and it's met all our expectations. It also fulfils our brief from the FIA to slow the cars.
The wider tyre does not bite through the snow as effectively, so the cars slide more. The wear might also increase, but we will see."
...[/i]
...the size has been changed as a cost cutting measure - it saves teams having to buy different sized wheels...
Snowshoes versus pogo sticks ?
Back to top
The following user says thank you to empip for this useful post:
arcticoceans (6 Jan 2010)
 Alert Moderators
RedHerring
from United Kingdom
Thanked: 27 times
PostPosted: Tue Jan 05, 2010 2:39 pm Reply with quote
Anticipation and assuming you don't have ABS, use your gears more for deceleration.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Tue Jan 05, 2010 8:44 pm Reply with quote
Dropping the tyre pressures was one old trick for getting out of as hole if you got stuck, but ONLY to get yourself unstuck, not for driving on afterwards.
Motorcycle trials riders used to recommend blowing the front tyre up until it's flat, 'and if you press down the valve on the rear tyre, the air should rush in', but their machines have the tyres bolted to the rims instead of relying on air pressure to hold them in place.
Back to top
The following user says thank you to TicklyT for this useful post:
 Alert Moderators
empip
Thanked: 50 times
PostPosted: Fri Jan 15, 2010 10:58 am Reply with quote
Driving on sand and the like I think lower pressures are used to increase the tyre footprint and therefore reduce surface pressure per unit area - seeks to do what we do not want on snow - decreases tendency to sink hence 'float' - I guess the mud situation is similar.
Certainly the rally boys will shift ( subject to rules ) from wide wheel /tyres to skinny kit when snow driving... Also use M&S very open tread patterns which tend to 'self clean'... obviously seeking traction and control.
-o-
Back to top
 Alert Moderators
timtheenchanter
from United Kingdom
Thanked: 58 times
PostPosted: Fri Jan 15, 2010 11:49 am Reply with quote
-o-
which has been my biggest problem, snow building up, essentially giving me a "snow tyre" trying to drive snow on snow, not fun!!
generally been fine, with proper typre pressures, and driving steadily.
oh, and ABS dont work on ice...
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General Cars All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
How to lower exhaust emissions? 22 3560 Wed May 25, 2011 11:26 am
Snow tyre clanger 22 1740 Thu Dec 23, 2010 12:53 pm
snow chains 8 6020 Mon Nov 21, 2005 8:35 pm
Snow chains? 23 2360 Mon Dec 06, 2004 11:49 pm
snow chains 3 600 Fri Dec 16, 2005 12:26 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
